Results 1 to 12 of 12
Thread: Alembic export. How to get a smooth mesh.
    Registered User DeedgeMinds's Avatar
    Nov 2012
    Winston Salem NC
    33
    I’m exporting an Alembic file of my animation to use in Unity. On importing into unity, everything looks fine except the mesh is no longer smoothed. I ca change the import settings in Unity so that it calculates the normals, but that results in strange seams appearing that correspond to my UV map. Everything I’ve read so far on Unity’s end says this must be fixed on the export (lightwave) side of things. Is there a way to export a smoothing normal map from lightwave? Using 2015.3. Thanks for any help in advance.
    Nov 2012
    Winston Salem NC
    33
    Ok. So for those also interested, I have found a work around to get smooth Alembic meshes in Unity.
    Export Alembic file out of Lightwave.
    Import Alembic file into Blender.
    You will see that the mesh is nice and smooth.
    Export Alembic out of Blender.
    In Alembic Export Settings, un-check "Pack UV Islands"
    Export.
    Now when you import into Unity with default import settings, you wil have a nice, smoothed mesh.
    Hope this helps.
    1,983
    so, use blender? that's not a great workflow. lightwave is the bottleneck there.
    Nov 2012
    Winston Salem NC
    33
    Yeah, I'm sure there are much smarter people than myself that could get it all working within LW.
    Its an extra step, but its solved my problem so far.
    1,983
    just out of curiosity, why not use fbx? I think unity still has the way to use a separate fbx for animation.
    https://docs.unity3d.com/Manual/Spli...nimations.html
    yep, using [email protected]
    Mar 2010
    SATown
    665
    Mdd?
    Would a good MDD importer for Unity be useful here? I've been working on one for awhile now, and I keep forgetting about it.
    I can bump that up on the priority tree if it's something people would use.
    -Chilton
    1,983
    you want something like maya/max game exporter that does animation clips:
    https://knowledge.autodesk.com/suppo...D0338-htm.html
    1,983
    watch the second video here:
    http://help.autodesk.com/view/MAYALT...2-67094E5C5624
    this one:
    https://help.autodesk.com/videos/c2e...yht/video.webm
    fbx review is free, hook it up to use that to review (just opening an fbx in explorer will open it once installed)
    https://www.autodesk.com/products/fbx/fbx-review
    Kamehameha Chameleon BigHache's Avatar
    Sep 2006
    Future Past Life
    1,899
    Quote Originally Posted by ConjureBunny View Post
    -Chilton
    That would not be unwanted. I'm currently using FBX and it's fine, for the moment at least. I'm just not keen on having a proprietary format like this at an integral part of the workflow.
    How would the file work in Unity? Would it be an animation that you apply to say an OBJ?
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,132
    Quote Originally Posted by BigHache View Post
    I see that this .MDD reader is available for Unity: http://www.west-racing.com/mf/?page_id=1335. Early this year I created a medical animation for a client. The client wanted to put this animation into an AR app. The animation included nodal control of morphs so it was not directly importable via .FBX. My client looked into using an MDD file but it turned out that the frame rate that the MDD file played was so slow that it was not practical to use it in an app. In the end we recreated the animation using only bones and morphs.
    6,684
    Quote Originally Posted by lertola2 View Post
    Chilton: If yours can replay MDDs for moderate-complexity objects at decent frame rates, it'd be quite valuable. However, that appears to be a tough nut to crack, based on how many seem to be having performance problems playing back "PLA-like" animation in Unity.
    Mar 2010
    SATown
    665
    That's exactly what happened to a friend's MDD based animation project a few months ago, for a (non-medical) AR app. That whole situation was what prompted me to put a little more polish on my own solution.
    Well I guess I need to find a moderate-complexity object with an MDD so I can find out!
    You wouldn't happen to have one of those lying around, would you?
    -Chilton
