Thread: wireframe AA in View Ports?
    gold plated 3D Chrusion's Avatar
    Chatannooga, TN
    1,080
    For some time now, and at least two different nVidia cards (Quadro K2000 and P1000), I've been unable to get any of the driver's AA settings to work in any version of either Modeler or Layout's viewports. Does LW simply ignore the GPU driver settings and substitute its own, non-AA settings, even when the vid card is told to override application settings? Specifically, wireframe lines/edges remain stair-stepped after changing driver properties (even after closing/relaunching Mod/Lay). Layout is the only app that has a "Grid Antialiasing" option, but none for wireframes/edges, and none in Modeler Display Options.
    Anyone get their cards to AA the viewports?
    Dean A. Scott, mfa
    Senior 3D Animator and Graphic Design Illustrator, @ Astec, Inc.
    Owner / Lead Artist @ chrusion | FX
    Pretty sure thats something that would have to be added by NT. In Modo for instance, AA wireframes is a feature of the advanced viewport and not available in any other type of viewport.
    15,096
    Quote Originally Posted by Chrusion View Post
    Yes..I got it to work, you may want to check this thread..but it may depend on your graphics card and lw version maybe, running 2015.3 here.
    https://forums.newtek.com/showthread...t=aa+wireframe
    geo messy madno's Avatar
    Feb 2009
    Germany
    794
    Here it is again - the famous yearly question about viewports and AA.
    What LW3D Group decided to be the default (watch at 100%):
    What I decided to use (watch at 100%):
    Card = Quadro K6000
    If settings in the Nvidia Control Panel do not work as expected it might be the internal profiles.
    What I did:
    • Searched for "Geforce 3D Profile Manager" (even though it says GEFORCE it works for Quadro as well).
    • Used the "Export SLI Profiles" button
    • Click image for larger version.
    • Opened the resulting text file and searched for the entries that it contained for Modeler / Layout (I think Modeler was "microwave studio" or so)
    • Deleted all those entries
    • Imported the altered text back in ("Import SLI Profiles")
    • In Nvidia Control Panel I made a new custom set for Modeler and Layout
    • Out of curiosity I checked the profiles text after making a new profile
    • Was happy because got AA in viewports
    EDIT
    Below information is wrong:
    Checked again. Frame Buffer does not cause lagging. Seems so, sub-d on the objects is it. I'll test more.
    Wrong ------
    Important:
    In Layout GL settings I needed to switch off "Frame Buffer Object" because it caused a horrible lagging (not checked in Modeler - it was off there anyway).
    What the documentation says about it:
    "Frame Buffer Object - accelerates color correction (slightly)"
    Wrong end -----
    Cross checked:
    Lag came from sub-d display. Changed "Display SubPatch Level" to 1 for all objects. Lag is gone now.
    EDIT 2:
    Cross checked with AA set back to "Application controlled" (= no AA). Lag is still there with "Display SubPatch Level" > 1.
    Chatannooga, TN
    1,080
    Quote Originally Posted by madno View Post
    LOL. Well, I usually search the forums, but 90% of the time, such returns nothing relevant. So, thought I'd hit it up with a new post.
    What I did:
    Thanks! That was helpful, except finding the profile tool. Here is where I finally found it (via a one word link in a forum post to another customer service post with this direct link) Geforce 3D Profile Manager.
    However, when I did the rest of these steps, Modeler & Layout (2015 & 2018) still didn't AA, so I exported the profiles again, in order to get the Modeler & Layout profiles that I had just manually added via nVidia Ctrl Panel, edited them to match your screen cap, imported, and BINGO! View ports were now AAing. So, just for giggles, I exported the profiles again to compare them to the one I just imported. Behold, extra parameters were added, most likely due to newer version of driver, etc.
    So that no one else has to manually type in the params by looking at a screen cap, here they are as text (EDIT PATHS TO MATCH YOUR INSTALLATIONS)...
    Code:
    Profile "c:\lightwave2015_3\bin\layout.exe" UserSpecified=true
        ShowOn All
        ProfileType Application
        Executable "c:/lightwave2015_3/bin/layout.exe" Name="NewTek Layout 2015" UserSpecified=true
        Setting ID_0x0019bb68 = 0x00000000 UserSpecified=true
        Setting ID_0x005a375c = 0x96861077 UserSpecified=true
        Setting ID_0x0084cd70 = 0x00000000 UserSpecified=true
        Setting ID_0x00a879cf = 0x60925292 UserSpecified=true
        Setting ID_0x00e73211 = 0x00000000 UserSpecified=true
        Setting ID_0x101ae763 = 0x00000000 UserSpecified=true
        Setting ID_0x101e61a9 = 0x00000001 UserSpecified=true
        Setting ID_0x1074c972 = 0x00000000 UserSpecified=true
        Setting ID_0x107afc5b = 0x00000000 UserSpecified=true
        Setting ID_0x107d639d = 0x00000000 UserSpecified=true
        Setting ID_0x107efc5b = 0x00000001 UserSpecified=true
        Setting ID_0x10d2bb16 = 0x00000001 UserSpecified=true
        Setting ID_0x10d773d2 = 0x0000001a UserSpecified=true
    EndProfile
    Profile "c:\lightwave2015_3\bin\modeler.exe" UserSpecified=true
        ShowOn All
        Executable "c:/lightwave2015_3/bin/modeler.exe" Name="NewTek Modeler 2015" UserSpecified=true
    EndProfile
    Profile "c:\lightwave_2018\bin\layout.exe" UserSpecified=true
        ShowOn All
        Executable "c:/lightwave_2018/bin/layout.exe" Name="NewTek Layout 2018" UserSpecified=true
    EndProfile
    Profile "c:\lightwave_2018\bin\modeler.exe" UserSpecified=true
        ShowOn All
        Executable "c:/lightwave_2018/bin/modeler.exe" Name="NewTek Modeler 2018" UserSpecified=true
    EndProfile
    Dean A. Scott, mfa
    Feb 2009
    Germany
    794
    Sorry to not post a link to the profile manager. I had forgotten that I also found it more or less by accident while searching for an AA solution.
    This was meant as my feeling about the status of AA. Year after year this question comes up and still no native AA in LW viewports. I really hope LW3DG will take care of this and other UI optimizations in the near future.
