Results 1 to 12 of 12
Thread: Tricaster 460 problems since update
    Nov 2014
    NJ
    9
    Just did the latest update on our Tricaster 460, and having some big problems now.
    1. Not seeing any video on my SDI inputs. Tried switching inputs, cables, cameras. I know the feed is going through cable since I hooked camera directly up to SDI monitor. Tried switching from Auto SDI to 108i directly, still nothing.
    2. Not getting any sound through headphones. At first, had DVI cable hooked to monitor and discovered I was getting sound through the monitor. Tried switching to HDMI, still nothing. Disabled the sound for the Monitor in Windows, still nothing.
    The update did have me update the computer video drivers. GT GeoForce 740. Other than that, haven't done anything different.
    Thoughts?
    Aug 2011
    Richmond, VA
    955
    Try the video drivers again after carefully looking at the hardware in the Device Manager. I have not had any luck having the Nvidia website auto-detect my hardware on the Tricaster.
    E. Lee Dickinson | President
    www.avprva.com
    Nov 2014
    NJ
    9
    Thanks Lee. I had problems with the auto-detect too, but wasn't sure which version of Windows to tell NVidia I had, so I guessed at Windows 7 64 bit. My Computer says Windows Embedded 64 bit, but that wasn't an option.
    FYI, I also did try to reinstall the Tricaster update just now. Got most of the way through it then got an error message that said the hardware was not detected.
    Nov 2014
    NJ
    9
    I let the re-install of the Tricaster update finish. Still not working. Exited to Windows and looked in Device Manager and the NewTek HD Video Class (1.02) has a flag on it. Error under Properites says "Windows can not verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or tha tmight be malicious software from an unknown source. (Code 52)."
    Also tried rolling back the GEForce drivers. Same result.
    Aug 2011
    Richmond, VA
    955
    Try a factory restore on the Tricaster, followed by the update, followed by the GeForce drivers. I had to do that on a 460 recently that was not detecting the Newtek hardware at all - not even with an exclamation point. I'm assuming something went weird in an update process between the NT drivers and the NV drivers, so I just started over and it worked. Took a while, though! You might also be able to get the Newtek drivers straight from support and get it done a little faster.
    www.avprva.com
    Thomas TV2
    May 2011
    copenhagen
    92
    I had the exact same problem with my 8000. Support told me to install this update and it worked :-)
    https://docs.microsoft.com/en-us/sec...s/2015/3033929
    But I am not to happy with the V5 update. It freezes, so I rolled back to V4
    Thomas
    Tricaster 8000 AE2
    Nov 2014
    NJ
    9
    The MS update fixed it! More specifically the link below. Had to have support tell me it was Windows 7, since didn't know what Embedded Windows was. Running it through the paces now, but at least it sees the hardware! Thanks for all your help!!
    https://www.microsoft.com/en-us/down....aspx?id=46148
    19,458
    Quote Originally Posted by abcwille View Post
    Just to add a contrasting note, I've been running ver. 5 (plus) on a Mini in daily use for well over a year now. I have run into a couple of builds that had issues, but generally these were obscure - either minor audio issues or to do with the execution of very particular automation requirements. This is not to trivialize apparent issues in the last build that some have encountered; being honest, I hadn't gotten around to installing it yet, and now i'm glad I didn't. This said, nothing would move me back to an earlier version.
    Toasting since 1990 edmellnik's Avatar
    Sep 2003
    Portland Oregon
    644
    I have been dragging my feet on moving my 860 AE vers1 to the latest version.... scared to death.
    From what I read, I may have to upgrade video drivers?
    IT would be good to know what version of AE is now free of audio issues etc.
    I have loved the AE version1. Did everything I needed stably but now may need to stream on facebook and from what I have read
    I may have problems with using version 1 of AE.
    My 860 is a 855 and software upgraded to 860 if that matters.
    Sounds like I should start this process when I have lots of time to call tech support.
    Ed
    Toasting since 1990
    Tricaster 860AE Owner
    Jul 2013
    Kansas
    470
    Thomas
    So what would I install from this link?
    Jul 2013
    Kansas
    470
    I found it. I installed it. I got it to work. YEAH.
    Registered User DStoneburner's Avatar
    University of Central Florida, Orlando
    174
    Quote Originally Posted by jopci View Post
    Thank you for this information. I just updated to the latest v.5 and was dumbfounded that I had no audio out. I decided to give this MS update that you provided and poof! Audio and now back. I really appreciate it.
