Results 1 to 9 of 9
Thread: Feature request NDI Studio Monitor
    May 2014
    Monaca PA
    34
    Feature request for NDI Studio Monitor.
    It would be really nice if you were able to reverse the image in the NDI monitor.
    It may sound silly but as a one man show, hosting and running the TC-1, if I could reverse the output of my TC-1 program feed and
    use NDI monitor in my teleprompter I could see the output of my show into the camera instead of looking at
    the output monitor above or the monitor to the left or right...
    The number one feedback I always get is why are you always lookin up or down?
    Its the simple things.
    You could do this using OBS with the NDI plug-in.
    Once you get everything installed. Add an NDI source which is TriCaster output. Then resize the source until you flip it around. To make it full screen, right click on the right monitor and choose Fullscreen output.
    OBS Studio: https://obsproject.com/
    NDI Plug-In for OBS: https://github.com/Palakis/obs-ndi/releases/tag/4.5.0
    Jun 2006
    Chicago, IL
    505
    Actually if you use the free Autocue QStart prompter you can have both a reversed and normal output from the application. It's can run via NDI and I've used a cheap Windows tablet to be the prompter output via WiFi. Works great! Alternatively you can also use the Intel Compute Stick to connect to an HDMI monitor too if the tablet concept doesn't appeal (I'm also using that and it works great, as well).
    Feel free to drop me a line if you've got any questions.
    Fritz Golman
    Hi Fritz,
    Thanks for your input on this. I've got a job coming up where i need autocue on a couple of cameras and i'm looking for a low cost option rather than hiring in a full rig and operator. With your QStart set up you mentioned using a "windows tablet to be the prompter via wifi". Do you mean you were able to send the output from the tablet via wifi to a second screen?
    Simon Malone
    Certified Tricaster Operator
    FreelanceVisionMixer.co.uk
    About Me | Day Rates & Kit Hire
    Jun 2006
    Chicago, IL
    505
    What I was saying was that you run Qstart (which has NDI output) on a pc that has a wifi card and run NDI monitor on the tablet and use WiFi connection to pick it up to display on the cameras as prompters. Alternatively, you could plug your tablets into a LAN via a USB ethernet adapter and go the wired route.
    Qstart features a secondary display channel that can be reversed for display on through the lens prompters.
    Aug 2016
    USA
    495
    We have a monitor right under the camera where the talent can either see the program output or their powerpoint or whatever they want. We feed it from a video output.
    19,352
    Just to mention it, among other benefits the LiveCreator feature in the upcoming version of PA gives you a TC-native teleprompter solution that can easily be distributed by NDI or another system output (i.e., SDI).
    Jun 2006
    Chicago, IL
    505
    How does that native promoter work?
    Is it using the voice recognition feature to advance or does it still need an operator to control speed, etc.
    I can see if it's using voice as a really cool option since it would allow prompters even when directing show as "one man band", which is usually how we run.
    Fritz Golman
    19,352
    For this round, at least, it is not voice actuated, Fritz. It has speed controls, and supports the ShuttleXpress USB controller.
