Thread: Connect Spark SDI/HDMI – WLAN-Connection Issues
    Jan 2014
    Germany
    67
    When the Spark's Wi-Fi connection to the Tricaster is interrupted and came back, video and audio are rarely restored automatically. Then I only see these pictures. An NDI studio monitor in the same network, however, shows an intact image. In the Tricaster I have to choose a different source and then the Spark again. In some cases, I have to restart the session. NDI-tools 3.6 is installed. The problem occurs with the SDI Spark and the HDMI Spark.
    Greetings,
    Hartmut
ID:	142463   Click image for larger version.
ID:	142464   Click image for larger version.
    Tricaster 460AE3 + 460CS
    3 x JVC GY-HM890
    Panasonic AW-UE70
    Newtek PTZ1 | Newtek Spark HDMI | Newtek Spark SDI
    Jan 2014
    Germany
    67
    Does anybody have the same problem? Does anyone have any idea how to fix this?
    3 x JVC GY-HM890
    Panasonic AW-UE70
    What version is your TriCaster software? If it current? Can you connect the Spark wired since it sounds like the WiFi isn't stable?
    Jan 2014
    Germany
    67
    We have the tc version 180323. If we use the cable connection, everything is ok. But we want to be on the campus with the camera. Then we come to the next access point and then the connection with the tc does not work. But the studio monitor in the same network as the TC shows the picture - so the wifi connection must be ok.
    3 x JVC GY-HM890
    Panasonic AW-UE70
    Oct 2010
    Chilliwack BC Canada
    13
    Had the same problem with the Tricaster a few weeks ago, and it happened right before we were to go live so we could not reboot the tricaster. Our work around was to put a copy of vmix on a laptop and grab the spark feed and use the vmix external output. That gave us another clean NDI feed from the spark unit so that we could use that camera.
