Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: Component based Scaling in Modeler??
  1. #16
    Mar 2016
    Oxford, UK
    762
    Oliver, your scripting videos were very welcome. Is it a case of taking any Python course on Udemy ? A LW based scripting course from you would hopefully sell like hot cakes.
  2. #17
    Quote Originally Posted by thekho View Post
    Use Polygon Islands plugins- http://mentalfish.com/2009/07/stranded/
    much more complete than my quick script.. i knew there had to be something out there... still, a great exercise.
    Oliver
    OD Tools Purchase Link: http://origamidigital.com/cart
    Vimeo Channel: https://vimeo.com/channels/850417
    Join ODRoot - https://www.odroot.com
  3. #18
    That's not the one I was thinking of so there is something else out there. Polygon Islands is interactive but you can't manipulate the view while the tool is active and the operations aren't undoable unfortunately.
  4. #19
    Quote Originally Posted by TheLexx View Post
    Ryan Roye already has a lw based scripting tutorial..
    Oliver
  5. #20
    Aug 2014
    South Bend, Indiana
    379
    Point Normal Move?
  6. #21
    Point normal move moves a polygon (or points/edges) along its vertex normals, not scale.
  7. #22
    Aug 2014
    South Bend, Indiana
    379
    True, but in turn this will sometimes "scale" an object depending on its shape.
  8. #23
    Well point normal move doesn't do any scaling. The reason some of the selections are growing are because the point normals along a 90 degree angle of a mesh are moving out diagonally so it is making the polygons larger but only because of a skewed translation. The polygons are also moving away from their original position which is not the desired result.
  9. #24
    I'm glad the mental fish solution got mentioned, it was going to be my next suggestion. I had the plugin but never loaded it for some reason, perhaps I was under the impression it was only 32 bit. Having played around with it now it's very nice, apart from the view being locked and no undo. I does what the original poster was asking for I think.
  10. #25
    Aug 2014
    South Bend, Indiana
    379
    It works with spheres
