Looking at some alternatives for different reasons. Have used another product for many years. I'm giving smedge a try but running into a problem that is probably easy for someone that knows. The command that LWSN.exe is getting throws an error of "Can't open scene file." It must be in how smedge has setup the command sequence or something. I know the file is there and my other product renders it just fine.
Thoughts? Below is a screen shot of what I am seeing. Top black section is a command prompt I paste the command into, to double check what it shows. The gray highlighted is from smedge itself in it's logs and the notpad at bottom is the actual command I paste into the command prompt from smedge.
Thanks for any thoughts.![]()
