Thread: What network requirement does a Tricaster have ?
    Sep 2017
    Vejle, Denmark
    5
    Hi
    For the past years, we've done a lot of streaming - always hooking up the Tricaster using a standard ethernet connection at the different clients.
    4 times this year, we've had no access (4 different clients) and they all tell us, that it might be due to some security limitations to their networks.
    In all 4 cases, the streaming button was pressed and and the counter goes to 0:0:0:13 and stops. In all other (50+) cases this year, there was no problems what so ever.
    Normally, I'd say that security - firewalls etc. - would be placed on incoming traffic and that outgoing would be fully open.
    Is there anything we can tell the clients to do to their network ? Does certain protocols need to be in place? Does certain ports need to be open ? Anything else ?
    Jun 2012
    Australia
    267
    For RTMP (most streaming you'll do) it's smart to ask for port 1935 (TCP/UDP) to be unrestricted out-bound. A proxy server will not be suitable.
    If they are blocking certain outgoing ports, that will stop your stream.
    For RTMP the default port is 1935. You would also want web ports open as well (ports 80 and 443) so you can monitor and communicate with the CDN.
    Network Ports.pdf
    Sep 2017
    Vejle, Denmark
    5
    Thank you
    I now found out that it can be testet before the actual project at portquiz.net:1935
