Results 1 to 12 of 12
Thread: Lightwave 2018.04 freezing for 5-8 seconds
    Newbie Member tonyhall007's Avatar
    Jan 2010
    nottingham
    85
    Blog Entries
    2
    Hi Everyone, I am using Lightwave 2018.04 on windows 10 and Lightwave layout freezes when I leave to use another application. When I clicks back onto layout there is a 5-8 second delay before I can start working again.
    Has anyone else come across this problem. I have put a bug report in, so hopefully it will get sorted.
    ack ack Markc's Avatar
    Feb 2006
    England
    1,353
    Just tried this out with another app on same screen and also on second screen, no freeze here on Mac.
    Mac Pro (2010) OSX 10.13 RX580 Pulse LW2019
    May 2003
    Ohio
    807
    Loose guesses...
    *Check Task Manager to see if the delay is due to low RAM and overflow writing to disk.
    *Video drivers up-to-date?
    *Firewall open for business on Layout/Hub/Modeler?
    San Jose, CA
    6,485
    Loose guesses...
    Agreed, this is the most likely culprit.
    @Tonyhall007: What's the memory consumption for Layout (according to Task Manager) when this is occurring?
    John W.
    Quote Originally Posted by tonyhall007 View Post
    Yes. It doesn't happen all the time. Something that I have discovered that seems to possibly cause it is changing content directory mid project. For instance when you are working on a project from one directory and then you need to render something up quick from another project. - You will probably have issues once you go back to your original project. The thing that seems to get it out of this funk is to close Modeler, Layout and the Hub and then start Layout but when starting Modeler be sure and start it from within Layout - not from your start menu or desktop.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Super Member Boris Goreta's Avatar
    Zagreb, Croatia
    1,347
    Ok, when this happens, kill Modeler and then try hopping from Layout to another app, is it any better ?
    I had the same problem on Win7, the update of the GTX drivers helped
    2D/3D Specialist
    http://www.render-up.com
    Win10 64bit, Dual Xeon E5-2696 V2 @ OC 3,3 GHz per Core, 64GB RAM, GeForce GTX 1080 Ti
    Jan 2010
    nottingham
    85
    Blog Entries
    2
    Quote Originally Posted by artzgo View Post
    Updated my Graphic drivers and so far seems to be fixed, thanks artzgo.Click image for larger version.
    I always start with updating GPU drivers, the latest ver. LW are released under the latest drivers ... I think so
    Good luck
    2D/3D Specialist
    pass:sword OFF's Avatar
    Russia
    1,001
    Installed a new driver - no significant changes.
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,472
    You may need to find a latency checker. Run it for a while, and take a look at what process is being laggy. Then, find out what it belongs to, and update it, if you can. I had some severe latency issues, and discovered that it was my NIC drivers from Microsoft causing the issue. Replaced 'em with the manufacturer's drivers, and everythings been solid.
    My Scripts for Lightwave
