Results 1 to 15 of 16
Thread: Best way to Import Particles from another application
    Hi guys,
    I like to import particles from another application and apply some additional work in Lightwave. I've been out of the loop for a while and not sure which file format works best? Does lightwave alembic support particles? There's also FBX, Collada, or mdds? maybe I should export the particles with small sphere geometries? Not sure how to best go about this. Any insight would be appreciated. thanks.
    Registered User Oldcode's Avatar
    Jan 2004
    Boston
    469
    Crook over at Foundation 3D says he'w working on a method to get Blender Particles into Lightwave. The results look good so far.
    http://www.foundation3d.com/forums/
    That looks awesome for Blender, but I'm actually trying to find a solution to get Modo particles into LW.
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,194
    I know I found a youtube video a while back about transfer particles from blender to modo using mdd. That workflow should work from modo to LW as well. Search on youtube...
    Ok, MDD didn't work. Actually, the only way to get particles out of Modo is to use Alembic support of Particles. I have to see if LW 2018 support importing that.
    it would be great, since that also would support Houdini particles
    8,076
    I made TrueArt's Node Library http://nodelibrary.trueart.eu
    CSV Reader node,
    which can read any .csv file..
    So if you will generate such file from 3rd party app (make custom script), you can get it in LW using this node..
    https://www.youtube.com/watch?v=EjD5_dusXSg
    Oliver Hotz has a pfx to alembic converter. I'm not sure if he ever released it as part of his OD tools but you can drop him a line to see if he would be interested in distributing it. With it I'm able to export my particles from Modo into any app that imports Alembic.
    Registered User Diepgroen's Avatar
    Jul 2016
    Amsterdam
    50
    Great converter, especially if you are doing Houdini work and back to LightWave. It's a bonus download among others when you get ODTools set, Windows Only.
    sounds good, heard the converter had a particle limitation? anyone knows if it got fixed?
    Jul 2016
    Amsterdam
    50
    pfx limits
    64bit has none, pfx could have
    Oliver Hotz:
    not the 64 bit version
    i THINK pfx has a limit though.. but i dont remember
    however.. transferring a couple million particles.. you'd be VERY VERY sorry in lw
    thanks! saved info!
    San Jose, CA
    6,892
    Quote Originally Posted by Diepgroen View Post
    Why is it Windows-only? What dependency drives that limitation?
    John W.
    availability of compiled alembic modules for osX.. and to be honest.. because it is a NIGHTMARE to do this stuff on the mac.. thats why.
    Oliver
    OD Tools Purchase Link: http://origamidigital.com/cart
    Vimeo Channel: https://vimeo.com/channels/850417
    Join ODRoot - https://www.odroot.com
    Jun 2014
    UK
    43
    Quote Originally Posted by Oldcode View Post
    I've been using VDB for blender smoke. If you can export in VDB format it may work for you. In LW2018 there's an openvdb node you can use.
