Thread: Poly split question!
    Creative Director jaxtone's Avatar
    Sweden
    1,500
    Hi, any one knows how to separate polys from each others without making a surface look weird?
    Curious
    Unweld.
    Detail Tab/ Points/ UnWeld
    Sweden
    1,500
    Wow! Thank you djwaterman! Shame on me for not knowing that and a big applause for you that so easily guided me right!
    Quote Originally Posted by djwaterman View Post
    Unweld.
    Curious
    Jan 2005
    Colorado Springs
    1,875
    RE: the second question in the posted image about using Fracture, I always use Preserve Original to keep the original geometry. Then in the scene I determine the frame where the fractured object starts to fall apart / explode / whatever and do a 1-frame (or a few-frame) Dissolve between the Original object and the fractured object which is originally 100% dissolved and parented to the original geometry.
    mTp
