Results 1 to 15 of 17
Thread: Realistic Grass
    Registered User 3dhotshot's Avatar
    Mar 2009
    Durban
    330
    Realistic Grass
    Is this good enough for the Lightwave gallery my 1m x 1m patch of grass ?
Name:	LW Forum.jpg
    Nov 2003
    Austria
    839
    hi, that is really nice, can you tell a little bit more how it is done, textured and lit (light, hdri).
    looks really great
    My Portfolio - http://alexs3d.blogspot.com - Now with Photography
    Mar 2009
    Durban
    330
    hi there, sure I didn't use any hdri just a jpg file in textured environment on Y at 120% opacity. no lights where used in scene just turned off so taking all light data from jpg file.
    for grass I used 3 separate layers so 3 different patches of grass on center pivot then instanced them on a 1m x 1m square played with settings
    for surfacing normal texture maps spec maps for grass blades with sum reflection to create shine effect on blades and helped with color variation of grass.
    Dof effect was Dp node image filter kit I placed a small cube in middle of the grass for focal reference point hid the cube from render.
    Final color was photoshop image color correct and get the right realism effect. you probably could do that in Lw as well under render buffers node.
    17,400
    Nice render there in the second image
    No seriously, your little grass patch is looking very good and would be fine in the gallery...But I would suggest to throw in something more to focus on, Like a ladybug or a grasshopper or a plastic bag maybe....sometimes there's so much beauty in the world i feel like i can't take it
    Aug 2006
    Eureka, CA
    7,099
    Quote Originally Posted by 3dhotshot View Post
    Like!
    shrox www.shrox.com
    Heavy Metal Landing
    I think the big picture is just the jpg used for the lighting, otherwise, if it were a render, I'd say submit that to the gallery instead. As to asking the forum if something is suitable for the gallery, there's no point doing that, just go ahead and submit it and you will find out if it is good enough or not.
    image = certainly a photo reference only  
    nice grass though, i like the render style.
    17,400
    Quote Originally Posted by djwaterman View Post
    You must be thinking right
    Why would he otherwise post his initial image and only describe that, and then referencing the second image as the "Light source"
    No one really mentioned anything about that second image being a render, other than with parody followed by a serious note, and shrox just happened to like that image
    If it were a render, so would my avatar image be as well...rendered in 1971.
    The big question now..Everyone ask themself, where is that place located really?
    southwest Europa?
    Living over there... MAUROCOR's Avatar
    Jun 2004
    Sao Paulo Brazil
    2,445
    Congratulations, very nice grass!!!
    Ground control to Major Tom
    Mar 2009
    Durban
    330
    thanks everyone ... @erikals I do watch some of ur videos and Dj w man your stuff is excellent.
    thanks, quite a lot of helpers on this page  
    keep LightWavin'  
    Mar 2009
    Durban
    330
    I did try to create falling rain drops on to the instances but could not get them to stick onto the surfaces. do particle emitters not interact with instances ?
    no, particles do not interact with instances or voxels/HyperVoxels
    it must be real geometry
    in this case though, using real geometry instead of instances should work fine,
    since there are not too many polygons in the camera view.
    Mar 2009
    Durban
    330
    ok cool thanks again ...
