Results 1 to 2 of 2
Thread: Tricaster 850 Extreme Audio Output
    May 2018
    Valencia
    4
    Hi, I know you can Solo certain audio channels and send them to Aux or Stream. But, can you also do it with the Master mix? I'd like DDR audio on Aux, but not on Master. Or can you have just one audio channel with the recorded file as am easy solution?
    Thanks.
    May 2004
    Vancouver, WA
    1,572
    You can use the color-coded grouping to accomplish that. Put any sources you want to go out the AUX output in the same group and assign that group to the AUX output. To keep them off the Master mix, just mute each source.
    Kris
    Replay: 3Play 820
    Cameras: Sony NX5
