Thread: Problem with IP Discovery on Linux SDK
    May 2018
    Ilmenau
    3
    Hi
    I've tested the Linux SDK a little bit and there is something that I didn't get to work.
    Normally the source discovery works with mDNS, but as I see in the API
    doku I can pass a IP Address to the searching process to ask.
    So I add one line to the NDILIB_Find example:
    NDI_find_create_desc.p_extra_ips =
    When I connect with netcat to port 5960 of a source I got an xml with
    source infos.
    I tried to debug with strace -re connect and I only see a connect to
    /var/run/dbus/system_bus_socket of the find process.
    Do you have any ideas what could be the Problem?
    Sep 2017
    London
    6
    Hi, for the automatic discovery to work I found I had to make sure the Avahi service/daemon is running and also disable the Linux firewall. Have not really tried the "extra_ips" method, though.
    Aug 2015
    london
    272
    Quote Originally Posted by j-licht View Post
    Hi
    source infos.
    extra_ips is not currently implemented on Mac and Linux.
    May 2018
    Ilmenau
    3
    Hi
    I've got an email that there is the new version 3.5.
    I teseted it with this version and it looks like it works.
    The server only sends a response on port 5960 if the avahi daemon is running.
    Aug 2015
    london
    272
    Hi
    ** Did you test whether extra_ips now works on Linux ?
    The 5960 service should be hosted by whichever NDI source was launched first (and is still alive). If that source closes, another current sender should immediately take over. I dont think it has *anything* to do with Avahi at all (thats the whole point of it).
    May 2018
    Ilmenau
    3
    Yes I tested on a linux.
    When the avahi doesn't run, I get no response when connect to the port with nc.
    I play a video with ffmpeg and used the NDIlib_Find example to test the extra_ip.
