Results 1 to 15 of 15
Thread: Metallics Grainy in 2018, but not in 11
    Charlesian2000
    Apr 2005
    Australia
    25
    Hi Guys,
    Absolutely puzzled here.
    A photorealistic render in 2018, is extremely grainy, but in 11 it's perfectly fine.
    If I use the Lightwave ball in 2018, it's fine, but my objects look terrible.
    LW11 Used the default Gold for 11
    2018 Used the default Gold for 2018
    What gives? Using the same camera settings. Adjusting the lights makes no difference.
    Not sure what's going on
    Charles
    16,833
    Quote Originally Posted by charlesian2000 View Post
    Hi Guys,
    Charles
    when you say adjust the lights, what did you do then? adjusting light samples often cleans up noice, depending on what kind of light you have..you need to raise samples quite a bit, otherwise you check the render panel and raise reflection samples etc, finally you try to raise camera aa sampling.
    Pessac
    5,203
    Go through this: https://docs.lightwave3d.com/display...Noise+workflow
    Things have changed in LightWave 2018...
    B
    LightWave 3D Trial Edition
    Jan 2005
    Colorado Springs
    1,862
    The default Gold surface in LW2018 has Roughness set to 40% and Bump Height set to 100%. If you lower both of those to 0%, the surface will be flat and reflect better and be less grainy. I didn't have your original groundplane for my setup, so the reflections in the block get a little funky toward the top - I just used your uploaded image on a Front Projection groundplane.
    mTp
    Attached Files Attached Files
    San Jose, CA
    6,981
    Quote Originally Posted by MonroePoteet View Post
    Well, that cleans up the surface, but doesn't address how dismal the surface looks color-wise, esp. compared side-by-side with the LW11 default Gold surface.
    Considering surface color's an aspect where PBR surfaces should look better by default, those results are... disappointing, to say the least.
    John W.
    May 2012
    Virginia
    551
    I think that has more to do with the RGB color in the preset; it's not really gold (which is generally sRGB 255, 215, 0) so specifically in a PBR render that actually emulates the physical characteristics, it isn't going to render out looking like gold.
    That seems more like an error on the part of the individual who created the preset; in this instance, they chose a color which is more like a bronze (sRGB 165, 113, 100) or copper (sRGB 184, 115, 51). Possibly, the gold surface color wasn't updated.
    Change the surface color values to the correct values, and the surface color will look more like gold.
    Malm÷, SWEDEN
    7,727
    This is what default Gold preset looks like in LW2018.0.4 on my machine (default gradient backdrop, environment light + GI).
    and here is one with an HDRI
    If I do a google search on Gold and look at images, it is obvious that gold has a wide spectrum of how it looks, especially the roughness.
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    AMD Ryzen Threadripper 3990X (64 cores/ 128 threads)
    64GB Ram
    Quadro 620
    Windows 10 Pro x64
    Jun 2014
    Right here
    1,816
    This thread confirms to me that 2018 has an issue with conductor / metallic shading quality. Not a single 2018 render I saw so far has any convincing metal surface. The quality / photorealism is nowhere close to popular 3rd party or built-in CPU or GPU render engines. In other render engines I use, I get immediate good results using reflectance, GGX or similar shading settings (using manual or HDRI lighting), even in the material preview or viewport.
    Malm÷, SWEDEN
    7,727
    How about this one?
    64GB Ram
    Quadro 620
    Windows 10 Pro x64
    Jun 2014
    Right here
    1,816
    Quote Originally Posted by Cageman View Post
    How about this one
    Thanks for posting, definitely better then the one before
    May 2003
    Ohio
    1,162
    How do you like this gold?
    LW4, 7.5D, 2015, 2018, 2019, 2020 running portably on a USB drive on an Amiga 2500 running Wine.
    Malm÷, SWEDEN
    7,727
    Yep... metals are very dependent on how you light them and what they actually can reflect. Metals in Octane or Redshift can easily look like **** if you don't light them properly. Will have some more exampels of different metals with proper lighting comming up.
    64GB Ram
    Quadro 620
    Windows 10 Pro x64
    May 2003
    Ohio
    1,162
    ...can easily look like **** if you don't light them properly....
    Indeed. That's what I was demonstrating in my non-LW noisy and poorly lit render above. That's a default gold preset rendered with a default HDRI in a program 2x as expensive as LW. I was attempting to show the not-so "immediate good results" one can find in other programs.
    Even if you have a preset metal material, you need the right reflected environment.
    Jun 2014
    Right here
    1,816
    Of course it's possible to create crap renders with every engine, the question is hiw much effort it takes to create a good one. In your example the render is very grainy and the bump mapping doesn't look right to me.
    Charlesian2000
    Apr 2005
    Australia
    25
    Found out what the problem was... it was the default gold preset, the roughness was cranked up... doh
    - - - Updated - - -
    Quote Originally Posted by Cageman;
    [ATTACH=CONFIG
    141733[/ATTACH]
    I do like this gold though
