Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Ddr timer through ndi?
  1. #16
    From Browser To Broadcast jmmultex's Avatar
    Jan 2004
    Trenton, NJ
    466
    I second using the Spark. It is part of our workflow specifically for capturing the main TC1 display, and we've been very happy with it.
    -john
    John Mahoney
    GNURAL NET, Inc.
    Trenton, NJ 08691
    [email protected]
    http://www.gnuralnet.com
    Gear:
    Gnural Net LiveToAir, TC1, TC1LP, MDS1, TC8000, Cameras: NDIHX-PTZ1, PTZ Optics ZCAM 20x
  2. #17
    Apr 2017
    San Leandro, CA
    14
    Quote Originally Posted by Lee-AVP View Post
    What I mean is that you would use the Spark to capture the interface components you want, then build your "stage view" in an ME using elements you're capturing. Same idea as Jeff proposed, but without running Scan Converter on your Tricaster.
    Please explain how to capture the interface components with a Spark.
  3. #18
    Jan 2004
    Trenton, NJ
    466
    You can take the output of your TC1 and feed in as an input into your Spark (via HDMI). The TC UI is now an NDI HX Source that can loop back as a TriCaster input and be composited as needed using an ME. Use an HDMI splitter if you need all your multiviews or just mirror the main UI display in Windows and use one of those outputs to feed the Spark.
    Hope that helps.
    John Mahoney
    GNURAL NET, Inc.
    Trenton, NJ 08691
    [email protected]
    Gear:
  4. #19
    Apr 2017
    San Leandro, CA
    14
    Quote Originally Posted by jmmultex View Post
    Hope that helps.
    I have a 460. Can I get the 460 UI as an output? If so, where do I find the output?
