Results 1 to 15 of 21
Thread: Merge objects in Layout?
    I just want to know if there is a way of merging objects within layout, kind of like in the similar vein of 'Save Transformed'. Even if there is an option to save multiple objects as one object then that would be fine. A plugin to do this would also be fine. LW 9.6 or LW 2018 but both would be cool.
    I realise that there may be surface conflicts, though, especially if you have two of the same objects with the same surface name but you choose to treat the surfaces separately in your scene and may have modified one of them. I'm sure there is a workaround for this.
    But the crux of the query is if this is possible or not?
    Revanto
    I'm a Mega 3D dude!!!
    Check out my friend's OLD Youtube tutorials
    Mix Mash's tutes
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    Sadly, dead link.
    Revanto
    Mix Mash's tutes
    Try Mike Green's Save Transformed lscript.
    http://www.mikegreen.name/Lscripts.html
    www.ernestpchan.com
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,201
    Save as fbx and load it back in.
    OD tools have some nice tools for this too
    Le Jardin Digital - Créations 3D / Design /Films - www.lejardindigital.fr
    yup
    Near Beaverton, OR
    2,038
    Quote Originally Posted by vipvip242 View Post
    I thought he did and was going to mention that earlier, but can't remember the name and using his Invoke Layout Command tool to search isn't helping find it either. You know what it's called?
    But I'm going to test Ztreem's suggestion for something quick 'n dirty.
    May 2003
    Ohio
    1,290
    Quote Originally Posted by Revanto View Post
    Sadly, dead link.
    Archive.org...
    https://web.archive.org/web/20110903...ne2Modeler.zip
    LW4, 7.5D, 2015, 2018, 2019, 2020 running portably on a USB drive.
    Active LW Development in 2020: DB&W | Deep FX | DPont | LWCAD | TrueArt | ...
    Wow, looks awesome! I'll give this a try.
    Thanks to you and everyone who added their two cents.
    Cheers,
    Revanto
    Mix Mash's tutes
    "object to dir" in layout to split layered objects in layout into separated saved objects (with dir. creation/selection)
    "directory collapser" in modeler to merge all the saved objects into one piece
    this is a very handy combination for many things, particulary for characters coming from apps like poser, which contain many pieces
    Sadly, Mike Green's script only half worked.
    But the Scene2Modeler script worked, albeit in a 2 part process but it did work in the end. It would be nice to have a one-step-process plugin or script but I can work with this for now.
    Cheers,
    Rev.
    Mix Mash's tutes
    Near Beaverton, OR
    2,038
    Thanks. I'd have never remembered their purpose from the names.
    8,356
    BakeScene works the best in LW 2015.3.
    It allows baking not just static objects, but entire animations to MDD files, or generate full scene object sequence.
    I was using it with e.g. objects with applied displacements in Node Editors.
    Super Member samurai_x's Avatar
    Jul 2015
    lalaland
    1,231
    There's a better way than all mentioned but Sensei's plugin is more powerful.
    Plus third party devs need to flourish in lw to continue.
