Results 1 to 2 of 2
Thread: Import function to save settings from one TriCaster version to the next
    May 2012
    Ohio
    43
    Made the Advanced Edition upgrade on my 860 from version 4 to version 5 only to realize there's no way to bring all the saved settings and customizations into the new version. I thought for sure I made a mistake in how I backed up my session but in talking with NewTek support, they confirmed revision 4 to 5 is not backwards compatible. Knowing how many hours went into all of the Comp Bins, M/E configurations, Macros, etc... it almost forces you to stay on version 4 unless you have a ton of time to burn on trying to recreate it all.. which is a huge inconvenience at best.
    My feature request would be getting some sort of import functionality / compatibility built into future revisions.
    Macro Titan JonRaidel's Avatar
    Sep 2009
    Los Angeles, CA
    216
    macros & ME/Presets should work, although they will need to be re-exported as MEM files. but you would need to rebuild a session.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
    Graphic Outfitters Scorebridge
    Livetext 3 w/ LT [Scoreboards 2]
