Thread: LightWave 2018 Depth Buffer issue
    Oct 2017
    Tokyo
    7
    I知 trying to get the Depth pass in LightWave 2018, but I知 getting a white image, even VPR Depth shows the same result.
    I have tested the same scene in LightWave 11 and it works fine.
    I知 wondering if I知 missing something.
    I checked and tested the solution provided in this section of the documentation, however did not work.
    Any suggestions/ideas will be highly appreciated?
ID:	140968   Click image for larger version.
    Attached Files Attached Files
    Mac Pro 2013, 3,5 GHz 6-Core Intel Xeon E5, 16 GB 1866 MHz DDR3 ECC, 2x AMD FirePro D700 6144 MB, MacOS X 10.14.5
    LightWave 2018, LWCAD 2018, ZBrush 2019, Fusion 9, Substance Suite, Affinity Suite.
    May 2007
    Belfort, France
    1,846
    For your depth buffer to appear correctly in VPR, you have to "normalise buffers" in VPR options. In image render viewer, the depth buffer final render shows as white, but when saved, it appears with the right informations. You can check the final result in the image viewer by ticking the small "n" button, which will normalise display.
    Jan 2005
    Colorado Springs
    1,795
    To add to CaptainMarlowe's excellent response: You have to specify an appropriate minimum and maximum Depth values in the Depth Buffer's render panel. If you leave it at the default (1Mm - 1 Megameter!), you'll just get black for anything even remotely close in the scene.
    BTW, I changed the DOF envelope to clear up the image for my testing.
    mTp
    Last edited by MonroePoteet; 04-01-2018 at 08:04 AM. Reason: Found VPR Options button
    Oct 2017
    Tokyo
    7
    Hi CaptainMarlowe and MonroePoteet,
    Thank you so much for your suggestions.
    It is working now! As you mentioned, doing both things solves the problem.
    Thanks again.
    Wow!
    This answer saved my day.
    Now I just wish I didn't spend the last 3 hours looking for a solution to why the Depth Buffer was not working no matter how big or small values I entered on the Near/Far fields! I was one step away to go back to the old trick of using Linear Fog with black matte objects!
    Some note regarding this should be helpful in the manual, near the depth buffer options.
    _____
    /- /|/| 3D Animation and Special Effects
    Dito
    sidenote; switch from "Linear" to "Cineon" mode to get a depth preview, tho' not accurate representation.
    Aug 2016
    a place
    1,853
    This kind of stuff should go in a tips section in the LW docs, so its not lost.
