Results 1 to 2 of 2
Thread: Problems over problems and such a weak documentation
    May 2017
    Lampertheim, Germany
    123
    I get more and more frustrated. Even the easyest things went wrong.
    Can anybody give me an example of how to use "move" in lwsdk.pris
    The module is initialized and all had functioned well... but move...
    if I do
    Code:
    movv=lwsdk.Vector(1.0,1.0,1.0)
    mcmd.move(movv)
    the Console Pops up and says:
      File "D:\NewTek\LightWave_2018.0.2\bin\lwsdk\pris\modeler\__init__.py", line 2466, in move
        return _move_code("MOVE", offset, arg2, arg3)
      File "D:\NewTek\LightWave_2018.0.2\bin\lwsdk\pris\modeler\__init__.py", line 2440, in _move_code
        elif isinstance(offset, (lwsdk.Vector, list, typle)):
    NameError: global name 'typle' is not defined
    using the same Vector with:
    mcmd.rotate(45,"X",movv)
    all goes well, so it seems the vector is right.
    and if i feed the move directly:
    Code:
    mcmd.move(1.0,1.0,1.0)
    I will get the following Error:
    even if I say
    Code:
    mcmd.move(float(1.0),float(1.0),float(1.0))
    I get the error
    Can anybody please help me out
    I am so frustrated about that Situation. Every Information must be searched bit by bit in hours and hours.
    Please help
    Regards,
    KANUSO
    May 2017
    123
    After hours of try and error, hours of searching for Information in the Internet, I thought that it is enough and changed the line with the error in the __init__.py for the pris/modeler
    here what I did:
    the original line (2440):
    which is in fact wrong !!!
    I changed it to:
    elif isinstance(offset, (lwsdk.Vector, list, tuple)):
    I changed from "typle" to "tuple" and all is going right now. I will use the Feedback Assistent to inform NT about this error
    Regards,
    KANUSO
