Thread: Connect Pro with three capture cards of Magewell
    Mar 2018
    China
    Can I plug in three MageWell capture cards in my Connect Pro computer? Can this be used?
    As I understand, Magewell supports multiple devices in a single computer, which in turn Connect Pro would be able to see. It comes down to the computer having the ability to support 3 cards while also having the performance needed to handle the video format in question. What video format are you trying to work with?
    1,613
    Might be better off to install one quad-input card rather than several single-input cards
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Registered User zenvideo.co.uk's Avatar
    Apr 2016
    Salford, UK
    27
    No reason why it shouldn't work - I often use a mix of three different Magewell cards in the same PC. If they're all the same type, then it helps (for ID purposes) if you use the ProCapture models where you can set a different ID number for each one via the rotary hex encoder/switch on the card.
    Martin Kay
    ZEN Computer Services - Salford, UK
    Oct 2017
    NY
    36
    Current version of Connect Pro has memory leak with Magwell cards. Newtek has fixed it but not yet published new version. Also make sure that new you have installed latest Magwell driver because drivers before 2018 has a bug that crash a system on Connect Pro exit.
