Results 1 to 9 of 9
Thread: M/E Output with Alpha
    Bloomington, IN
    1,636
    I'd like to be able to build complex graphics using an M/E then feed that to a DSK WITH an Alpha channel. Currently the output of the M/E has a black background.
    The simplest way to do this is to simply honor the alpha data in the last M/E layer the same way you do the other seven layers. Add a check box to disable this function for those occasions when you want a black background.
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    Gear Used: TC1, NC1 I/O, TC 460, TC Mini 4k.
    19,785
    I understand what you're asking for, but just want to mention that you can kind of do this now using the M/E's LiveMatte features - not the same, but useful anyway.
    Bloomington, IN
    1,636
    Yeah, I'm just imagining a big macro driven sports scoreboard system with no external computer necessary. Everything is there ( 8 layers, comps, animated buffers etc.) to implement it except the alpha channel from the M/E.
    -Jeff
    My TriCaster Blog
    Jan 2014
    Nashua, NH
    30
    Is there a tutorial / quick tip to the Live Matte Feature somewhere?
    Apr 2008
    Racine
    1,673
    Live Matte tutorial video: https://vimeo.com/90171613
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Jan 2018
    Winter Park
    545
    I used the alpha method but it also meant no transparencies in the items in the ME
    Aug 2016
    USA
    560
    What if you right click on the preview monitor, select say M/E1, click on the gear and access LiveMatte for the M/E?
    Jan 2014
    Nashua, NH
    30
    @Stream - I've done this before adding an additional layer to a default Live set with a solid 'Key' Color from a buffer with sometimes effective results. Earlier I missed the fact that LiveMatte is what they Keying technology is called.
    Under an ME / Live Set Picker / Utilities - there is a Garbage Matte and Inhibit Matte - Does anyone know how these are used and if they are useful in the above situation?
    19,785
    My recollection is that these are basically inversions of one anther. On uses a layer to act as a typical garbage matte for the key, while the other prevents the keyer from removing background color where the matte layer is opaque.
