Thread: Extend ethernet cable
    Mar 2018
    Czechi
    2
    Question Extend ethernet cable
    Hi
    Is it possible to extend ethernet cable length (to achieve length of 100m and more) e.g. by adding a switch every 100m and then use this for NDI? I’m thinking about using TriCaster and NDI system for live concert broadcasting and heavy duty fibres are too expensive so I need to extend normal metalic cables.
    Thanks!
    Yes, you can use a switch to do this. How many are you expecting to go thru? Having a few switches inline should not be a problem.
    Mar 2018
    Czechi
    2
    Hi Kanep, thanks for your reply. I’ll probably never go for more than 200 meters, so 2 switches max...
