Thread: NDI output from Tricaster 460
    Registered User SteveRother's Avatar
    Jul 2007
    Las Vegas
    30
    I may be missing something but is there a way to send the Program Mix on a 460 advanced edition to another NDI enabled computer using the NDI Tools kit?
    Steve Rother
    Lightworker
    Las Vegas NV
    Jun 2006
    Chicago, IL
    522
    Yes, that's the whole idea.
    The 460 with AE has NDI available mirroring all output channels as well as the inputs. Nothing else required.
    You just need to load the tools package on the computer you want to see the output on and then run the NDI Monitor app (which is one component in the tools kit). In the NDI Monitor app you'll select whatever you'd like to view from the 460. If you don't want to install the application on the computer you can also run the Monitor application as a stand alone executible using the Portable Tools package.
    It's that simple, assuming your network has visibility between the 460 and the destination computer.
    Cheers!
    Fritz Golman
    PS will you be at NAB? I see your signature says you're in Vegas.
    USA
    502
    I use Newtek Connect for that purpose.
    Jun 2011
    Austin, TX
    Hello. Is there something I need to turn on in order to send the Output from my 460 through NDI? I can see all 4 Inputs along with all 4 M/E's, but the laptop cannot see the Program Output.
    1,655
    In Output Config panel, check the box for NETWORK
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
