Thread: Luminous color in 2018
    Why is it that when I convert Layered to Principle Nodes, do I get a Luminous Color connection in the node editor? I think its only on surfaces with a texture map, but I could be wrong. I have been disconnecting it as I don't know why it's needed. Can someone please explain to this old dog?
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    aka Ken9 DuneBoy's Avatar
    Sep 2005
    Los Angeles, CA
    280
    That connection is made, and the color value/env is transferred, because the Standard Material uses the base color for its luminescence. Whereas the Principled Material can use a separate color value for the luminescence. Therefore to maintain the look that was setup via the Standard node, the color/env/connection conversion is made to both the Color and Luminous Color of the Principled Material.
    If that transfer wasn't done the converted surface would be luminous with the default gray color.
    Ken Nign
    Thanks for the detailed answer Ken!
    Tim Parsons
    Technical Designer
    Aug 2016
    a place
    1,798
    Quote Originally Posted by DuneBoy View Post
    couldn’t you just have luminous col be set only if luminous values are set in the std material?
    does it have to do it for everything? btw this would be good as an option - convert wih no luminous hook up if it does do it for all.
    San Jose, CA
    6,487
    File it as a feature request (or bug, I can see justifications for calling it either). If there's no luminosity set, then for UX reasons it really shouldn't auto-hook it into that port, because doing so gives the visual impression something is being used when it really isn't.
    John W.
    Aug 2016
    a place
    1,798
    yeah i’ve been running into that, ‘tis why i ask. thanks for reply. i’ll try and add a feature bug request
