Results 1 to 1 of 1
Thread: 4 - AVIPAS 20x (PTZOPTICS 20x) robotic cameras for sale with 4D IP Super Controller
    Jun 2013
    Los Angeles
    40
    I have 4 - AVIPAS AV-1051 PTZ robotic cameras for sale.
    They are exactly the same as PTZOptics 20x cameras.
    These are really great cameras for the money.
    These work really well with the Tricaster. They were used on 2 shows, so these are like new. No dings, scratches, scuffs..in perfect condition!
    They have both HD-SDI and HDMI out. They do not have NDI, but you can add a connect spark hdmi to make them NDI and wireless. (If I don't sell them, that is what I'll end up doing)
    They have IP video, and IP ptz control that works great with the Tricaster. You can save blocked shots to memory and call them up from the Tricaster or the IP Controller. PTZ control from Tricaster Control Surface as well. You can even save a macro with a moving shot, pushing in or out with the press of one button.
    The IP Super Controller again is the same as PTZOptics IP Controller.
    They come with the original boxes they came in, with all the remote controls, rs-232 cabling, power supplies, etc.
    I'm asking $4,900.00 for 4 cameras and the IP Super Controller or best offer
    If you're interested, email me directly at [email protected]
    If you purchased the same cameras and controller from PTZOptics they would cost you:
    4 - PTZOptics 20x - $1,699 x 4 = $6,796.00
    1 - PTZOptics IP controller - $649.00
    TOTAL $7,445.00 if you purchased 4 PTZOptics cameras.
    That is 65% less than buying the PTZOptics brand.
ID:	140366Click image for larger version.
ID:	140367Click image for larger version.
ID:	140369Click image for larger version.
ID:	140371Click image for larger version.
ID:	140372Click image for larger version.
    Here are the specs:
    The Avipas AV-1051 is a 1080p IP camera with 20X optical zoom and 16 digital zoom is suitable for video conferencing, education, stadium and houses of worship. The AV-1051 has multiple outputs including HDMI, HD-SDI and IP Streaming (H.264).
    20x Optical Zoom & 16X Digital Zoom
    Full 1920x1080p HD Resolution up to 30 frames per second
    High performance extremely low 0.5 LUX rating
    2D and 3D noise reduction with low noise CMOS sensor
    Audio input for audio-video streaming application
    IR Remote w/ Fast/Slow PTZ Controls
    Resolution & Frame Rates1080i/60, 1080i/50, 1080p/30, 1080p/25, 720p/60, 720p/50, NTSC, PAl
    Panasonic Video Sensor1/3" CMOS, Total Pixel: 2.2M, Effective Pixel: 2.12M
    Scanning ModeProgressive
    Tamron Lens20x F4.42mm - 88.5mm, F1.8 - F2.8
    Lens Zoom20x Optical &16x Digital
    Minimal Illumination0.5 Lux (atF1.8, AGC ON)
    Shutter Speed1/25s - 1/10000s
    White BalanceAuto, 3000K/Indoor, 4000K,5000K/Outdoor, 6500K_1,6500K_2,6500K_3,One-Push, Manual
    Backlight CompensationSupport
    Digital Noise Reduction2D&3D Digital Noise Reduction
    SNR>= 55dB
    Vertical Image Flip & MirrorYes
    Horizontal Field of View60.7 deg. - 3.36 deg.
    Vertical Angele of View34.1 deg. - 1.89 deg.
    Vertical Rotation-30 deg. - + 90 deg.
    Horizontal Rotation+/-170 deg.
    Pan Speed Range1.7 deg. - 100 deg./s
    Tilt Speed Range1.7 deg. - 69.9 deg./s
    Preset Accuracy0.1 deg.
    Presets255
    WDROff, Low, High
    Video coding standardH264, JPEG
    Video StreamMain stream, Sub stream
    Main stream resolution1920X1080, 1280X720
    Sub stream resolution720X480, 320X240
    Bit Rate128K,256K,384K,512K,768K,1024K,1536K,2048K,307 2K,4096K,5120K,6144K,8192K Optional, customize
    Bit Rate TypeVariable rate, fixed rate
    Audio standardAAC
    Audio rate96K,128K,256k
    Support protocolsTCP/IP, HTTP, DDNS, RTSP, PPPoE, SMTP, UPnP, SNMP,FTP(Optional)Maximum Frame
    Format PAL:1-25, format NTSC:1-30
    I Frame GapCustomizable,(must be greater than or equal to the maximum frame rate)
    Video FormatPAL, NTSC
    Web Video SizeOriginal/Full-screen/Appropriate size
    IP TypeDynamic IP address, Static IP address
    DNS TypeManual DNS, DHCP
    E-mail FunctionSupport
    FTP FunctionSupport
    CaptureAuto/Manual capture
    RecordManual/Timer record (SD Card needed)
    Motion DetectionSupport
    User PermissionSupport
    HD Output1xHDMI: Verision 1.31xHD-SDI: BNC Type, 800mVp-p, 75Ohms, Along to SMPTE 292M standard
    SD Output1xCVBS: RCA jack, 1Vp-p, 75Ohms
    Network Interface1xRJ45: 10M/100M Adaptive Ethernet ports
    Audio Interface1-ch 3.5mm audio interface, LINE IN
    USB1x USB2.0: A type jack
    Communication Interface1xRS-232 IN: 8pin Min DIN, Max Distance: 30m, Protocol: VISCA/Pelco-D/Pelco-P
    1xRS-232 OUT: 8pin Min DIN, Max Distance: 30m, Protocol: VISCA network use only1xRS-485: 2pin Phoenix port, Max Distance: 1200m, Protocol: VISCA/Pelco-D/Pelco-P
    Power jackJEITA type (DC IN 12V)
    Baud Rate2400/4800/9600bps
    Power12W
    Input Voltage12V DC (10.8 - 13.0V DC)
    Ceiling InstallationYes
    Operating Temperature23 to 104 deg. F (-5 to 40 deg. C)
    Storage Temperature-4 to 140 deg. F (-20 to 60 deg. C)
    Dimensions142 x 169 x 176mm (5.59 x 6.65 x 6.93")
    Weight1.5kg (3.31lbs)
