Page 6 of 6 FirstFirst ... 456
Results 76 to 86 of 86
Thread: Lightwave 2018 fireflies
  1. #76
    After 8 months of using LW2018 I can happily say that fireflies are mostly a thing of the past. If you are loading older assets look at the bump maps to see if they are causing your fireflies. Also don't be afraid to crank up your keys lights to 32 samples. Some higher sample settings really effect render times, while others not so much.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
  2. #77
    and than we come to reflection noise...
    new web page up www.null.hr
  3. #78
    So you believe most have no need for HDR image render output, then?
    I don't know what needs most people have when rendering. I do know that this method worked in this particular case. Also, most people may assume that you can only limit the dynamic range from 0 to 1. You can enter a number higher than one and the images are still HDR. I was able to use this setting as sort of a clamp to eliminate the brightest of the fireflies.
    Also, as I've said, it doesn't affect the render buffers and only affects the final output. This is not my preferred method, but in this case it was much better than cranking up sample settings and increasing render times.
  4. #79
    Dec 2017
    blue
    31
    hello,
    just about the 'firefly' an example;
    (gray color is chrome)
    all light; volumetric samples;34 samples; 34
    the mac version crashes is a horror, as soon as you change the light settings manually
  5. #80
    Quote Originally Posted by Obi View Post
    hello,
    Do you need volumetric samples set so high? Are your lights volumetric? That setting is for the graininess seen in the fog from the lights. You could try adjusting your speculator samples.
  6. #81
    Dec 2017
    blue
    31
    Quote Originally Posted by Axis3d View Post
    no volumetric, but I search speculator samples...
  7. #82
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,526
    I think he means reflection samples, under the render tab on the render properties panel.
    My Scripts for Lightwave
  8. #83
    Apr 2016
    Barcelona, Spain
    568
    Hi, is this carpaint shader? It makes a lot of fireflies. If so, change it to principled.
    Regards
    Salvador Ureņa
  9. #84
    Dec 2017
    blue
    31
    Yes Asticles, carpaint shader
    Kryslin; Thank you
  10. #85
    Registered User pnevai's Avatar
    Nov 2003
    South Florida
    55
    Eliminating fireflies in light wave 3D
    Quote Originally Posted by Morgan Nilsson View Post
    What are your lighting settings? My first guess would be that you are sampling the backdrop from multiple sources which is causing too high contribution to indirect specularity.
    If using environment light, don't sample backdrop in GI, same goes if you use portal lights. At the same time, if you are not sampling the backdrop in GI switch the shaders to raytrace reflection and refraction only.
    Below is a link to an excellent tutorial on how to get rid of those pesky fireflies in you renders. It goes through step by step on how using environment lights can get rid of those rendering artifacts.
    https://www.youtube.com/watch?v=72AAwSFx4nA
  11. #86
    Nov 2003
    South Florida
    55
    What he said.... I found it helps dramatically with the firefly issue.... Turn off glossy reflections.
