Thread: AE Mix/Effects Question
    May 2007
    St. Paul, MN
    783
    I'm not sure if I'm doing something wrong or not since my experience with AE is limited.
    Here are my sources:
    NDI graphics feed with alpha (scorebug)
    SDI camera source (live clock)
    Other SDI cameras for game coverage
    I have created a mix effect with the scorebug and the clock as a PIP. I want to turn that M/E in to a DSK for the program feed. Whenever I try to bring the DSK in, the alpha is lost so I see the bug and the clock surrounded by a whole lot of black. Am I doing something wrong or is the alpha lost as it passes out of the M/E bus?
    Zach Schuster
    SuiteCG- Sports Scoreboard and Stat Tools
    Tricaster 855/460
    Zeplay Instant Replay
    ScoreOCR
    Sony NX5U
    Apr 2008
    Racine
    1,668
    No, alpha is not passed thru the M/E as you are trying to do. Your A/B/C/D layers are going to form the background, with alpha appearing as black then.
    Which TriCaster model? Your signature only lists 855/455.
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    19,455
    The output of an M/E is normally a fully opaque frame, just like the output of the main Switcher. You could, I suppose, use LiveMatte to remove a colored background in the M/E for use in a DSK, but there might be better approaches.
    May 2007
    St. Paul, MN
    783
    Thanks for the reminder on my signature. I have updated it.
    I'll have to see if I can just bring them both in as separate DSKs. I was hoping to avoid that, but it wouldn't be the end of the world.
    Zach Schuster
    Tricaster 855/460
    ScoreOCR
    Sony NX5U
    From Browser To Broadcast jmmultex's Avatar
    Jan 2004
    Trenton, NJ
    461
    Would it be possible for you to put it in the DSK and crop it using the edge controls? If you needed 'non-square' edges, you could use a second DSK to overlay it with an image with the center part transparent.
    Just a thought...
    -john
    John Mahoney
    GNURAL NET, Inc.
    Trenton, NJ 08691
    [email protected]
    http://www.gnuralnet.com
    Gear:
    Gnural Net LiveToAir, TC1, TC1LP, MDS1, TC8000, Cameras: NDIHX-PTZ1, PTZ Optics ZCAM 20x
    Aug 2011
    Richmond, VA
    955
    Props to both Steven and John for pretty elegant options. You could also use a macro to trigger the two DSK's to come up together, if you have enough DSK's available to work with.
    Being able to toggle transparency would be a really cool feature to add to the already powerful ME reentry features, though. Feature request it!
    E. Lee Dickinson | President
    www.avprva.com
    May 2007
    St. Paul, MN
    783
    I think I got it. I am able to set up my DSK inside M/E 1, then set up a luma key and key it out. Success!
    Thanks!
    Zach Schuster
    Tricaster 855/460
    ScoreOCR
    Sony NX5U
