Thread: Can we please get a shader node example for LW2018 LWSDK?
    San Jose, CA
    6,485
    Title's pretty self-explanatory. While lwsurfaceshader.h APIs, etc. is included in LW2018 SDK, and bears similarity to lwshader.h APIs, etc. from prior SDK, it would still be quite useful to have a proper example of using the new lwsurfaceshader.h approach to implement a simple example (and ideally, a not-so-simple example, f.e. SSS, as well).
    John W.
    7,891
    What you have in lwsurfaceshader.h is for making "Shading Model", that you set in Surface Editor top most tabbed menu.. and then drop-down of them..
    Renderer asks for Material that user set in Node Editor, ATM built-in Principled BSDF or Standard are filling LWBSDF (created by LWBSDFFuncs by LW),
    then Photoreal Shading Model (or yours handler) is called with LWBSDF that has been returned.
    You analyze supplied LWBSDF using LWBSDFFuncs, and output something.
    SSS node you should make using lwnodes.h
    If you have Material output, LWBSDF is already passed to your node.
    In Evaluate():
    LWBSDF bsdf = Output_GetValue( value );
    ( *m_BSDFFuncs->resetBSDF )( bsdf ); // just example
    // create LWBXDF and attach them to LWBSDF
    San Jose, CA
    6,485
    Thanks, I really appreciate the info! I have a few questions, but easier to give context, etc. in email -- probably won't get back to that project for a couple weeks, unfortunately, work's busy.
    Still, actual samples would be nice too.
    John W.
