Results 1 to 15 of 20
Thread: nuArchitect bundle extensions
    May 2017
    Lampertheim, Germany
    126
    Hello,
    to not create a thread for every Extension of nuArchitect bundle, I create this thread. All coming extensions will be placed here. I hope this is in the sense of everyone.
    Regards,
    KANUSO
    May 2017
    126
    nuGothBlk
    nuGothBlk is used to create gothic-style blocks
    nuGothBlk.zip
    May 2017
    126
    nuPlaque
    nuPlaque is to create Plaques.
    nuPlaque.zip
    May 2017
    126
    nuTombstone
    nuTombstone is to create tombstones.
    nuTombstone.zip
    Murcia, Spain
    3,005
    Thanks Kanuso
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    May 2017
    126
    Hello,
    the Installation notes (sorry for not posting them with the first entry):
    All zip files are build identically. They include every file which is part of the Extension and should be installed as follows:
    All files with the fileextension .ls should be placed in your pluginpath of LW (this is where the other .ls-files of the nuArchitect bundle are)
    All files with the fileextension .html should be placed in the help-Folder of the nuArchitect Folder (this is where the other .html-files of the nuArchitect bundle are)
    All files with the fileextension .jpg should be placed in the img-path of the help-path of nuArchitect (this is where the other .jpg-files of the nuArchitect bundle are)
    All other files should be placed in the folder you have entered in the preferences-tab of any geometry creating script of the nuArchitect bundle
    Sorry again for the late description
    Regards,
    KANUSO
    San Jose, CA
    6,486
    Quote Originally Posted by KANUSO View Post
    Hello,
    Just to be sure I understand, where does the nuArchitect folder itself go? The same folder (plugin folder) as the .ls files? Or where?
    Also, from what you've said, it sounds like the hierarchy should go as follows:
    plugin folder/
    - *.ls files
    - nuArchitect/
    - - help/
    - - - *.html files
    - - - imp-path/
    - - - - *.jpg files
    Does that look correct (presuming nuArchitect folder goes in plugins dir)? If nuArchitect folder goes elsewhere, does that at least reflect the proper hierarchy _under_ the nuArchitect folder?
    Thanks!
    John W.
    May 2017
    126
    Hi jwiede,
    to use the extensions, you should have installed the nuArchitect bundle.
    Here i give you a hint of what is going on:
    plugin folder/
    - *.ls
    - main folder of nuArchitect (it does not matter how you will name it, and it does not matter where you create it. This is the path you should set in th preferences-tab). In this example it will be named "nuArchitect".
    for example:
    - nuArchitect/
    -- help/
    --- img/
    --- css/
    --- js/
    in the "help" folder *.html
    in the "css" folder style.css (which is included in the nuArchitect-bundle)
    in the "js" folder nu.js (which is included in the nuArchitect-bundle)
    all other files are going directly into the nuArchitect folder. (no .ls - no .html - no .jpg - no .css - no .js - is found there
    I hope this is giving you a hint.
    Regards,
    KANUSO
    San Jose, CA
    6,486
    Ah, that is much clearer, thanks!
    John W.
    May 2017
    126
    nuArchStones
    nuArchStones is to create arches made of stones.
    nuArchStones.zip
    Install this as described in this thread.
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,675
    Hi kanuso. I was just wondering, do your scripts run as individual scripts run by the user (ie: on their own)?
    May 2017
    126
    Hi daforum,
    I am not sure if I understand you right.
    Do you mean each script of the bundle separat? Yes, they do, if they are installed right. Each part of the bundle works for its own. They share only a path for input and Output and help.
    Or do you mean if the scripts run without LW? No, they do not.
    If you want for example only some scripts, than you can delete all other scripts (*.ls) and their corresponding help files and graphics. But why not installing all? Is it because of the disk space they need?
    If this is the reason and you can work without help, than you can delete the help-folder of the nuArchitect-bundle iclusive the subfolders in it.
    If this is not the reason, than describe what is the reason for your question.
    Regards,
    KANUSO
    May 2006
    Bristol, England
    1,675
    Hi kanuso,
    Yes, just like a regular script.
    Your bundle is fantastic and i was just curious if they work as a regular script without having to install everything else.
    Thank you,
    Daforum
    May 2017
    126
    Quote Originally Posted by daforum View Post
    Some scripts are using files from the "nuArchitect" folder. If these files are not present, than there is nothing to create for these scripts. You will mostly notice this by empty sketch-boxes.
    With other words: at least this Folder should be present and filled with its files.
    The helpfolder and its subfolders can be deleted (of course no help will be available than).
    Regards,
    KANUSO
    May 2006
    Bristol, England
    1,675
    Hi Kanuso,
    Thank you for the info
