Results 1 to 9 of 9
Thread: A sudden LW15.3 issue
    Time Traveller Andy Webb's Avatar
    Hertfordshire UK
    2,156
    I've just been working on a couple of scenes for a client in LW15.3 and noticed this error when I load them in:-
    "Can't find specified server"
    I tried loading the scenes into LW2018 and no error.
    The scenes load and render OK, it's just bugging me as to what might cause it.
    It seems to be on every scene I load in now, has anyone any idea what it could be?
    Cheers
    Andy Webb
    Intel core i7-3820 3.60GHz
    Asus P9X79 Deluxe motherboard
    GeForce GTX 660
    32 Gb RAM
    Windows 10
    7,900
    Many old servers (plugin handler class, nodes, shaders, image and pixel filters) have been removed in LW 2018.x
    Try running Filemon (or similar utility for monitoring disk activity),
    maybe it'll show up as file with .p extension, which can't be found.
    It could be shader (LWSHADER_HCLASS).
    Try loading the all .lwo objects in scene which is showing it, each alone in LW 2018.0.1.
    If there will be error message, you will know it's caused by some plugin handler (node, shader, image filter attached to some image).
    Otherwise open .lws in text editor,
    and try searching for "Server" keyword.
    It could f.e. Spot Info node used inside of Displacement or Motion Node Editor or some Compound node.
    Hertfordshire UK
    2,156
    After saving an empty scene and clearing different Master Plugins, I found that the error is caused by Auto Render Saver!
    Any thoughts, I'll try reinstalling and see if that solves it. I've used it for years but I can remember having this issue once before...
    Andy Webb
    GeForce GTX 660
    32 Gb RAM
    Windows 10
    Hertfordshire UK
    2,156
    Re-downloaded Auto Render Saver and re-installed it but still the same problem...
    Andy Webb
    GeForce GTX 660
    32 Gb RAM
    Windows 10
    7,900
    I see where might be problem..
    When there is executed command
    "RemoveServer ImageFilterHandler [index]"
    f.e.
    "RemoveServer ImageFilterHandler 1"
    But server has been removed,
    LW is showing message "Can't find specified server".
    Hertfordshire UK
    2,156
    So is that a problem?
    I checked and the saver still works...
    Andy Webb
    GeForce GTX 660
    32 Gb RAM
    Windows 10
    7,900
    Download plugin version 2.2, and check whether message is still appearing or not for couple days.
    http://www.trueart.eu
    Hertfordshire UK
    2,156
    Hi Sensei, that worked a treat, thank you very much for sorting it.
    Just puzzled as to why the problem suddenly appeared, unless I just never noticed it.
    Andy Webb
    GeForce GTX 660
    32 Gb RAM
    Windows 10
    7,900
    Quote Originally Posted by Andy Webb View Post
    Bug. Now is dead.
