Results 1 to 13 of 13
Thread: VLC v3.0
    VLC v3.0
    VLC Player v3.0 has been released. One of the new features is that it supports native NewTek SpeedHQ media playback.
    https://www.videolan.org/developers/vlc-branch/NEWS
    However, VLC v3 is currently not compatible with the NDI plug-in, so if you need that workflow do not update yet.
    Key Accounts Sales Engineer
    Apr 2017
    Massachusetts
    181
    VLC 3.0 is pretty great so far!
    Any ETA on a 3.0 plugin? Or a Mac version, for that matter?
    TriCaster TC1 #1
    TriCaster TC1 #2
    NC1 Studio I/O Module
    TriCaster Mini SDI Advanced #1
    TriCaster Mini SDI Advanced #2
    Video Nerd
    I don't know when it will be released, but I am currently beta testing a VLC v3 NDI plug-in, so it being worked on. I'm not aware of an OSX version.
    May 2007
    St. Paul, MN
    783
    Any Update on This?
    Any update on this for Windows? I'm trying to get VLC running an NDI feed. How far back in VLC do I need to go to find a working version (currently gone back to 2.2.6 but still not working)? I'm using the current release of NDI Tools.
    Zach Schuster
    SuiteCG- Sports Scoreboard and Stat Tools
    Tricaster 855/460
    Zeplay Instant Replay
    ScoreOCR
    Sony NX5U
    The current NDI Tools will work with VLC 2.2.x (2.2.8 was the last release). The new NDI Tools (which should available soon) will add support for VLC 3.x versions.
    Make sure you install NDI Tools (again) after installing VLC so it will install the plug-in.
    Feb 2015
    Los Angeles
    8
    When will NDI tools with the VLC Plugin for VLC 3.0 be released?
    I don't have a date, but I think it should be out this month. (No guarantees) It will be included with the NDI Tools 3.5 release.
    Oct 2018
    USA
    1
    Hello,
    I just installed VLC 3.0.6 , as well as NewTek Tools version 3.8. After some uninstall and reinstalls, I was able to get VLC to see the NewTek NDI video and Audio outputs. I chose a short video to loop, the Studio Monitor on the same system saw the VLC as an option for an NDI feed, and my other system saw it as well. The Studio Monitor on the local system with VLC broadcasted the video the first time, then went to a green screen. The audio continues to play through the looping of the media in VLC. The second system on my network played a black screen only, and did not receive an audio feed either.
    I did a fresh install of VLC and NewTek on another laptop on the network, and I was successful at getting the video and the audio to work for a while, then the video froze, the audio kept working, and a green screen showed up.
    Any suggestions here? I think this technology is going to change everything so I want to make sure that I can make all of the basics work to their fullest. I use VLC frequently, and the combination will be amazing when it works. All help is appreciated.
    Paul
    The green output issue is caused by the having 'Automatic' or 'Direct3D 11' hardware accelerated decoding selected. Change it to 'Disabled' or 'DXVA 2.0' and it will not turn green.
    Registered User Red Dog Records's Avatar
    May 2008
    Northern California
    293
    Kane,
    We have had the 'green screen' show up with other NDI sources before. In particular when comparing a Spark HDMI to a Bird Dog Studio. They were using the same source, same network, but the Bird Dog gave us a green screen (with flickers of video on occasion), while the Spark was always solid. We just figured it was an issue with our network dealing with the 'full NDI' of the Bird Dog Studio.
    Are you saying this could have been caused by the 'allow hardware acceleration' setting on the Studio Monitor application?
    Andrew
    Tricaster 460AE3 + LC-11
    Flypack: Router, switch, backup encoders, captioning devices, audio mixer, UPS, etc
    Cameras: Sony Z280, Z150, Spark & Bird Dog converters
    http://reddogrecords.com
    Quote Originally Posted by Red Dog Records View Post
    Kane,
    Andrew
    No, this is not what I'm speaking about. The green output issue I'm speaking of is specific to using the NDI plug-in and VLC Player when VLC Player has certain hardware decoding options enabled.
    BirdDog has developed their own NDI chip, if you are seeing issues, you need to contact BirdDog. I'm not sure what the cause of that would be for green output.
    May 2012
    Worthing
    157
    I have updated my VLC to 3.07 but the NDI Plugin isn't installed in the codecs. I have re-installed NDI Tools 3.8 and that didn't work and I have uninstalled VLC done a fresh install and then re-installed NDI Tools and still the NDI Plugin isn't listed in the Video codecs. This used to work before I updated VLC any one have any ideas?
    PI have found that VLC loads into "Program files(x86)" as standard but NDI Tools loads the plugin into "Program files" as standard. So I have reinstalled VLC into the same folder that NDI Tools loads the plugin into and then re-installed NDI Tools but VLC still doesn't list NDI as one of the outputs in the codec list. This used to work until I updated to 3.07.
    I will try and download a previous VLC.
    I have downloaded 3.05 and I have got it to work. I too get the Green screen if I play a file as a loop the second and every consequent play of the file sends a GREEN screen on the NDI stream.
    May 2012
    Worthing
    157
    I have got the stream to work but again I am not getting any video content. I have run NDI analysis and it claims the NDI stream is a NDI/HX type. I have also sent a NDI stream from OBS on the laptop and that is also discovered on the network but has no video when seleceted. Finally I am running VMix and that is discovered on the network and the video stream does work. All 3 stream sources though are marked as NDI/HX in NDI Analysis.
