Results 1 to 2 of 2
Thread: Resetting Polygon Positions in Endomorph
    Jun 2017
    down
    18
    Is there anyway to select some polygons in an endomorph and return them to their base position?
    EDIT: Solved it, select the polygons you want to reset and use Map->General->Clear Map
    Quote Originally Posted by gra View Post
    Note that the clear map button works relative to what kind of map you have selected on the lower right corner of the UI. It means that this same button is used to clear UV maps, Color vertex maps, weights, endomorphs, etc.
