Results 1 to 10 of 10
Thread: Can someone confirm a bug for me? 1-2-3 PFX crash
    3D Mac Maniac Scazzino's Avatar
    Boston area
    2,555
    Exclamation Can someone confirm a bug for me? 1-2-3 PFX crash
    Hi can someone confirm a bug for me? I want to make sure it's not just my setup before I report it and see if it's Mac only (I'm on El Capitan) or across the board. I'm currently testing a Discovery version of LW2018 so I can't save a scene, but it's so simple you don't need to save anything.
    Try this in Layout 2018.0.1
    1) Add a Null
    2) 'p' to open Object properties and add an FX_Emitter
    3) Set the emitter Nozzle to Object-Vertices and hit Calculate
    Here Layout immediately crashes. Same thing happens in 2015.3 which crashes both Layout and the Hub.
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0 com.newtek.LightWave.ParticleFX 0x000000011a13a8c4 0x11a0e8000 + 338116
    1 com.newtek.LightWave.ParticleFX 0x000000011a0f69aa 0x11a0e8000 + 59818
    2 com.newtek.LightWave.ParticleFX 0x000000011a0f7992 0x11a0e8000 + 63890
    3 com.newtek.LightWave.ParticleFX 0x000000011a0f94f3 0x11a0e8000 + 70899
    4 com.newtek.LightWave.ParticleFX 0x000000011a0fa96c 0x11a0e8000 + 76140
    5 com.newtek.LightWave.ParticleFX 0x000000011a110102 0x11a0e8000 + 164098
    6 com.newtek.LightWave.ParticleFX 0x000000011a110cf5 0x11a0e8000 + 167157
    7 libtools.2018.0.1.dylib 0x000000010c289c7e 0x10c15e000 + 1227902
    8 com.newtek.LightWave.Layout 0x000000010bb68222 0x10bada000 + 582178
    9 libtools.2018.0.1.dylib 0x000000010c18ecd1 ActionDefDispatch + 145
    10 libtools.2018.0.1.dylib 0x000000010c1b05f1 CmdEntryFireTag + 193
    11 com.newtek.LightWave.Layout 0x000000010bb245d4 0x10bada000 + 304596
    12 com.newtek.LightWave.Layout 0x000000010bbcbab9 0x10bada000 + 989881
    13 libtools.2018.0.1.dylib 0x000000010c1bd2bf 0x10c15e000 + 389823
    14 libtools.2018.0.1.dylib 0x000000010c1bd756 0x10c15e000 + 390998
    15 com.apple.AppKit 0x00007fff9cc553c9 -[NSWindow _handleMouseDownEvent:isDelayedEvent:] + 6322
    16 com.apple.AppKit 0x00007fff9cc563ad -[NSWindow _reallySendEvent:isDelayedEvent:] + 212
    17 com.apple.AppKit 0x00007fff9c695539 -[NSWindow sendEvent:] + 517
    18 com.apple.AppKit 0x00007fff9c615a38 -[NSApplication sendEvent:] + 2540
    19 libqcocoa.dylib 0x0000000119ca4c7e -[QNSApplication sendEvent:] + 78
    20 libqcocoa.dylib 0x0000000119ca1257 QCocoaEventDispatcher:rocessEvents(QFlags<QEventLoop::ProcessEventsFlag> ) + 1351
    21 libtools.2018.0.1.dylib 0x000000010c17bb29 0x10c15e000 + 121641
    22 libtools.2018.0.1.dylib 0x000000010c2c720a WManGetInput + 442
    23 com.newtek.LightWave.Layout 0x000000010bc0f889 0x10bada000 + 1267849
    24 com.newtek.LightWave.Layout 0x000000010bcb6bed 0x10bada000 + 1952749
    25 com.newtek.LightWave.Layout 0x000000010bae6f44 0x10bada000 + 53060
    MikeS [LWProfile] 30+ Yrs of Award-winning Media DreamLight.com
    Drag-and-drop-dead-easy™ ScreamerNet - DLI Constellation
    BOOK - Creating a 3D Animated CGI Short & 3D CGI Short Films & DLI Blog
    15,904
    It crashes here too, the thing is, it shouldn´t crash, it should however give you an error message saying..there are no vertices to calculate.
    After all...what to expect? you added a particle emitter to a null object, which has no points/vertices..so when calculating it looks for something that isn´t there..CRASH BOOM BANG.
    Verify, add a box, p- for properties and add particle emitter fx on that, change nozzlel to vertices.. and calculate and see what happens.
    Frequenter
    Sep 2003
    Munich
    411
    Crashes here also (Win7, 2018.0.1) - Tried a (layout created) CubeObject which worked fine...
    7,981
    Confirmed on LW 2018.0.1, and bug reported..
    Boston area
    2,555
    Thanks for the confirmations. I reported it.
    Of course you wouldn't normally set an emitter to object vertices on a null (because there are none) but it shouldn't crash Layout. It would be nice if it generated particles from the pivot of the null. That's what I was trying to see if it would do (so I wouldn't have to create a one point object) but it crashed instead. What I really expected it to do was nothing, because there are no points. I certainly didn't expect it to crash both Layout and the Hub. That should never happen regardless of user input or it means some special case input has not been checked/trapped for errors.
    15,904
    Quote Originally Posted by Scazzino View Post
    Absolutely, it shouldn´t crash, and error message just saying not valid or something would be nice.
    for generating from the pivot, just add a particle emitter and scale down emitter size to zero, for it to start emitting out as in normal directions, you need a little vibration, perhaps combined with explosion, but only explosion do not work, you could also just set some velocity m/s in one of the x-y-z coordinates, but scaling it down to zero allows for it to emitt from a pivot point.
    Boston area
    2,555
    Here's another crash.
    1) Add a null, press 'p', fx tab and add an emitter
    2) Click the calculate button twice (not a double-click).
    3) Switch to the Primitive tab before the calculation finishes.
    Here layout crashes when the calculation finishes.
    I reported it, but let me know if it also happens for you guys too anyway.
    Boston area
    2,555
    Yes, you could do that. I just create a one point object and use that. It would be nice to have an option for pivot point in the emitter though.
    Had this same issue. Reported 2 weeks ago.
    Boston area
    2,555
    BTW: The calculate button should only permit one calculation (canceling any previous calc in progress). Currently you can hit it many times and it spawns many calcs with windows all stacked on top of each other, and then crashes when done. Looks like you don't even need to switch tabs to trigger the crash. The reason I was switching tabs was because I was trying to reproduce another bug where the fx_emitter was showing in the geometry tab (primitive tab in 2018) custom object list rather than just the fx tab list as it should. It happened to me when I was working and then crashed so I was trying to see how it got that way. It was like that tab was showing the wrong list or something.
    - - - Updated - - -
    Quote Originally Posted by bazsa73 View Post
    Which issue? The null calculate crash, or the multiple click calculate button crash?
