Results 1 to 2 of 2
Thread: What framerate records the ISOCORDER Pro?
    May 2017
    Germany
    27
    Hello my question is in which frame-rate the ISOCORDER Pro records?
    Is it possible to record in 50 or 60 frames per second if you select for example a couple of NDI signals which deliver this framerate?
    There is no information about the frame-rate on the website
    Thank you very much in advance
    NDI IsoRecorder will record at the same resolution and frame rate that the NDI channel it is set to. If the NDI source is 1080p running at 50/59.94fps, that is what it will record.
    You can test with the free version of NDI IsoRecorder. It will create the same video file that the full version of IsoRecorder Pro will do.
