Thread: Can Tricaster be used on anything wider than 16:9 screens?
    May 2010
    Manchester, UK
    60
    Hi everyone
    We have just finished two events using ultra-wide LED screens. We have a TC1 but only ended up using it as a backup media server because we needed something that could handle 9600 x 1344 pixels on the first show (25m wide screen) or the 3456 x 1080 on the second show (8m wide screen). We had to use a very expensive Barco E2 instead.
    In theory the TC1 could have handled the smaller of the 2 screens but we can't set the resolution to anything other than the normal sizes.
    So my question is, is there any way that we can set the screen sizes to anything wider than 16:9?
    Look forward to hearing your thoughts
    I"m assuming you are talking about creating a session in a non-standard SMPTE video resolution? That isn't something the TriCaster can do right now, all sessions are in standard SMPTE video formats and aspect ratios. With NDI, TriCaster can receive non-standard SMPTE video formats, but it always outputs in a SMPTE video standard.
    May 2010
    Manchester, UK
    60
    Yes. This is one of the shows we do. We can get the TC1 to fill most of the screen but there are obviously huge areas top and bottom that it is also sending signal to but are not being used. It seems like a relatively simple operation to send those same pixels in a different aspect ratio.
    Technical Account Manager - Channel Support
    Sep 2005
    NewTek
    1,705
    I suggest contacting our UK office https://www.newtek.com/contact-us/ while TriCaster doesn't support this out of the box there are ways of making this work with the help of our Professional Services team.
    Zane Condren
    NewTek Inc.
    new.tk/call
    TriCaster 860 PortaStudio
    Mar 2009
    Mililani, Hawaii
    118
    My facility has a 10 screen briefing room with controller (CineMassive). I've experimented with using two outputs from the TriCaster which can be spread across 4 screens each. Maybe that would work for the widescreen production.
    From Browser To Broadcast jmmultex's Avatar
    Jan 2004
    Trenton, NJ
    458
    If you are only using the screen for pre-rendered content like backgrounds, intros, video playback, etc, you might be able to create your video in something like FCPX or Premiere using the exact resolution of the ultrawide LED screens, distort it on export to fit into a 16:9 aspect ratio, then stretch it across the screen on playback - essentially treating it like anamorphic content. The human eye typically has more visual acuity vertically than horizontally, so it shouldn't be perceived much differently from a non-standard aspect full resolution video. This also doesn't require any specific outboard gear or need additional outputs.
    Just a thought.
    -john
    John Mahoney
    GNURAL NET, Inc.
    Trenton, NJ 08691
    [email protected]
    http://www.gnuralnet.com
    Gear:
    Gnural Net LiveToAir, TC1, TC1LP, MDS1, TC8000, Cameras: NDIHX-PTZ1, PTZ Optics ZCAM 20x
