Thread: Looking for a way to get a nice audio fade in/out macro
    Jul 2015
    Kirkland, WA
    124
    I'm trying to record a sound fade in/out in macros.
    I tried to edit the times and haven't been able to get a smooth curve with a decent duration.
    Any suggestions?
    Thanks,
    Rob
    Rob Safran
    Share Wisdom Network
    [email protected]
    TriCaster: 460 AE
    TalkShow: VS4000
    Gnural Net CM & LTA
    VSE and LiveText
    Cameras: 2-Sony PMW-X70, Sony PXW-Z150
    Registered User epavideo's Avatar
    Jul 2016
    Washington DC
    80
    I have a sound fade macro on my SOUND channel. It's set at 100% in the macro editor, not "Snapshot".
    I recorded it realtime and it should look something like this:
    I also use a Launchpad as an audio mixer. The 3 vertical bars on the right are virtual faders that I can slide my finger up and down on to produce a fade:
ID:	139730 sorry the attachment is sideways.
    each macro button has a single db level: -60db dim green at the bottom(MUTED) and +10db Full red at the top; just slightly above unity, -0db
    Here's the macro script:
    Quote Originally Posted by rlsafran View Post
    Any suggestions?
    Thanks,
    Rob
    Jul 2015
    Kirkland, WA
    124
    I had recorded unmuting the Sound and increasing the volume from the lowest level to my desired output level of +14 dB, but hoped there was a built in macro command to do a nice fade-in or out. I ended up trimming the lower dB range entries and tighten'd up the delays to .5 frames each and it's working much better. Thanks...
    Rob Safran
    [email protected]
    TriCaster: 460 AE
    TalkShow: VS4000
    Gnural Net CM & LTA
    VSE and LiveText
    Jul 2016
    Washington DC
    80
    Cool. Yeah I haven’t found any pre-existing macros for this.
    Jul 2019
    Stockholm, Sweden
    11
    I agree, would be great to have a macro that would do a soft fade. Something like "input1_volume_fade_to"
    //Martin
