Thread: Ghost in the Machine
    USA
    499
    Sometimes, I'll open up a session and it will start doing transitions all by itself.
    I can put the same source in program and preview and if I leave it like that for a while it stops.
    Most of the time everything is fine. wondering if anyone has any ideas what might be going on.
    I'm not using any macros or touching the keyboard. I'm on 171027 and they had me force update the core.
    Jan 2018
    nz
    22
    Yes, for us this happens intermittently - every couple of days. A wipe transition will perform without any user or macro instruction issued. We have a slightly bigger issue with the version but will dig into it more when I have chance.
    Bloomington, IN
    1,615
    Stuck spacebar on the keyboard?
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    USA
    499
    I've gotten it to this.
    It now happens on just about every session I open, even new ones.
    My shows usually start going from GFX2 to DDR1. So I load up, let it happen, then I have to put program and preview to GFX2
    and move the fader bar on the control surface up and down and then it will usually play nice. It also only seems to happen between media players.
    Also the green lights near the fader bar will go out and return to normal after moving it up and down. Also just found out (I'm getting ready for a day of live shows), if I first put
    gfx2 in program and preview, shutoff autoplay in DDR1 then put DDR1 into preview and then turn on autoplay, it doesn't happen. It like it's automatically deciding to play whatever
    media player is in Program. I'm not touching any buttons, keys or using any macros.
    USA
    499
    Found the Ghost.
    A lot of the sessions had autoplay checked in GFX1 and GFX2.
    D'oh!
    The moment when you feel accomplished yet somewhat stupid and the very same time.
    I'd start with only a monitor keyboard and mouse directly connected to the system (don't use a KVM extension or USB hub).
    If the issue has gone away, then connection one device at a time and test again. I realize this can be time consuming, but hopefuly it should help you figure out what is causing the problem. I'd also trying another keyboard connected to the system just in case.
    If the problem is still occurring with only a keyboard/mouse/monitor, then I would contact NewTek support.
    USA
    499
    Hey Kane.
    I think that we were typing at the same time.
    Thanks again!
