Page 1 of 4 123 ... LastLast
Results 1 to 15 of 52
Thread: Lw2018 Extruding challenge: How?
    London
    2,342
    The challenge: how can we do an animated extrudes in LW2018 now we don't have DP Kit or SG Fertiliser?
    Here’s two very simple setups in LW2015, can this be replicated as easily in LW2018 with the new Mesh nodes? Would love to see examples.
    https://youtu.be/cBJi8gi_Z60
    good question,
    over at FaceBook, there were 3 alternatives
    -Fertilizer (plugin)
    -Trailer (plugin)
    -Linedraw (by Alex Hartley) (LW2018 point offset)
    short on time here, but i find the last (native) Point offset interesting
    for the curious ones, read more at,
    https://www.facebook.com/groups/ligh...13069422132387
    https://www.youtube.com/watch?v=K3gAfMi7eiM
    edit; however couldn't make it work on geometry, only 2 point poly chains
    London
    2,342
    Haha, cheers Erikals, that was my post That’s a great technique, will post it later but nothing other than polychains at the moment.
    Ps, I can’t get Fertilizer to work on the Mac anymore, I think Triler is something slightly different. \
    Quote Originally Posted by raw-m View Post
    and an important post!
    i just found out, it works on geometry, just make sure the point order is correct!
    so, progress!
    London
    2,342
    so, progress!
    How did you find that out, this is as far as I got: https://www.facebook.com/groups/ligh...3478288758167/
    17,382
    I think we really need a way in 2018 to use weight maps anyway, those are created specificly for branching, extruding a single pipe objec as long as you got right amount of points and correct order is one thing with nodes, but when branches split..hmm.
    London
    2,342
    Thanks, school boy error - totally forgot to check the point order! Nice feature in 2018, Point Info will display the points when selected in the window. The downside is that the numbers disappear when you click off the window. Good start though!
    my little experiment.
    Attached Files Attached Files
    London
    2,342
    Amazing!!! I’m not at LW right now but will check later - got a feeling a might get a little scared if I open up that compound node! Big thanks
    Looking at it, I think this probably better than Shifter as the polys don’t move around the path.
    I forgot to mention the mode (set):
    London
    2,342
    Quote Originally Posted by N_A View Post
    Great! I’ve noticed the little equals sign in the Displacement node means “set”.
    Michael Nicholson zapper1998's Avatar
    spokane washington usa
    4,678
    Blog Entries
    1
    wow nice
    ASUSTeK COMPUTER INC. ROG STRIX TRX40-E GAMING Rev 1.xx
    1 x Ryzen Threadripper 3970X 32-Core - 3690 MHz (32 cores, 64 threads) Fractal S36 AIO
    131072 MB DDR4 DIMM 2133 MHz (8 of 8 slots)
    London
    2,342
    Just a quick update to say THANK YOU N_A. This extrusion node is SO GOOD!!! And I can kind of follow what's going on in the compound node for future reference.
    LW3dg should really put a node library of this stuff together - or at least some kind of sharing online resource, (built into a preset shelf?)!!
    somewhat related, here is a link to Part Move operations in LW2018 >
    http://forums.newtek.com/showthread.php?156018
