Thread: How to transfer 10-bit video throuth NDI?
    Jan 2018
    China
    1
    In online document NDI Encoding/Decoding there describe formats about 10 or more bits support as:"The most common implementations are expected to utilize 8-bit UYVY and RGBA video, however support for 10-bit and 16-bit is available. The internal pipeline of the codec is maintained entirely at 16-bit or better.". But I checked the SDK, there is no 10-bit FourCC type supported, like v210, p010 and so on.
    I wonder how to do with NDI to transfer 10-bit video?
    Thanks.
    Nov 2018
    Amsterdam
    4
    Me too! I have an application that needs to stream some high quality depth camera information, and 8 bits is not really enough.
    Nov 2018
    Amsterdam
    4
    To be more specific, I see that in Processing.NDI.struct.h, the NDIlib_video_frame_t struct defines a video frame explicitly in terms of 8-bit, i.e.:
    Code:
    // The video data itself
    uint8_t* p_data;
    So that seems like a non-starter. If NDI supposedly "supports" higher bit depth, how do we practically make use of this in our applications?
    NewTek Engineering ACross's Avatar
    San Antonio
    795
    All the SDK actually does is define it in terms of a pointer. What we need to do however is support FourCC's for higher than 8bit precision which will (almost certainly) be in the next version.
