Results 1 to 11 of 11
Thread: Nurbs surfaces in 2018.0.1 don't work anymore?
    Intermediate User Shloime's Avatar
    Sep 2003
    Germany
    103
    Hi. Just updated to .0.1 and noticed that nurbs created with LWCAD don't seem to work anymore. In 2018.0 all looked fine and rendered perfectly, and now in 2018.0.1 I just get lines and a few filled polygons. No change done to the object file, just used new version of Layout. Is there any config entry I missed, some checkmark I didn't set?
    Greetings, Shloime
    Win10 64, Ryzen 5 1600, GTX 980 ti, 32 GB, LW 2018
    Lightwave Pimp Skonk's Avatar
    Yorkshire UK
    1,450
    Working fine for me.
    uh wha?
    7,884
    One thing that users absolutely must remember is the way you install custom polygon handlers plugin class.
    such as LWCAD NURBS, EasySpline, Bezier.
    After adding plugin, you must quit Modeler, then restart it again, and then you can start adding menus.
    Custom polygon handlers are very low level plugin class.
    So, if you installed new version of LW, loaded scene, but plugin is missing, and it is asking for plugin to add, showing file requester.. No.. you can't do that with custom polygon handlers.
    If you did it above way,
    find LWCAD in Edit PlugIns,
    remove it entirely.
    Quit LW.
    Start LW.
    Add Plugin.
    Quit LW.
    Start LW again.
    Then start adding menus.
    Then you can run tool using custom polygon handler.
    If you won't do it appropriate way, very strange abnormalities can happen..
    Sep 2003
    Germany
    103
    OK, now I understood my error: Somewhere on the LWCAD page it says "LW can display nurbs since V 2015". In my head I interpreted this as being a native ability. I didn't realize I had to install LWCAD first to use this feature.
    Happens when you take some things for granted.
    Apologies to LWGroup, error resides between my ears.
    Greetings, Shloime
    Oct 2008
    Delaware
    80
    LWCAD [WSUR] Nurbs Surfaces not displaying applied morphs in Layout
    Using LW2018.0.1
    I already submitted a report to WTools, just seeking confirmation here...
    Morphs applied to simple LWCAD nurbs (flat) surfaces are visible only while in Vertices view. When a morph is applied to nurbs surfaces, only the (base) position is displayed or rendered. The scene & morphs I'm testing worked fine in LW2015.3, and newly created nurbs surfaces will reproduce the effect. The Morph Mixer modifier is checked and placed at the bottom of the modifier stack.
    7,884
    Quote Originally Posted by Meshman View Post
    Using LW2018.0.1
    But what with LW 2018.0 Build 3063... ?
    Sub-patches are frozen in Layout 1) when object is loaded to Layout and/or 2) every single frame.
    From your description it sounds to me that freeze of sub-patches were done only after loading object to Layout,
    instead of freezing them every single frame.
    How about such case: set frame to some other than 0/1. Imagine you have 100% morph at 20 frame. Set frame 20.
    Save scene. To store current frame in file.
    Reload scene.
    Is it in base position or at morphed?
    Oct 2008
    Delaware
    80
    Thanks Sensei,
    LW 2018.0 Build 3036 showed the same issue. I updated to 2018.0.1 with the hope that the issue would be resolved.
    Setting up a new scene with a morph applied and saved as you instructed produces the same results. The morph bounding box and vertices move but the surface remains in it's base position.
    morph should be before subdivision?
    7,884
    Quote Originally Posted by UnCommonGrafx View Post
    Good idea, to check.
    LW normally asks custom polygon handler to give mesh at every frame.
    But in LW2018, you do it using drag'n'drop modifiers in hierarchy..
    Oct 2008
    Delaware
    80
    I've tried switching the positions in the modifier stack. And yes, only when the Morph Mixer is placed below Subdivision does the morph's bounding box become visible, and show the animation when scrubbing the timeline. The mesh remains displayed at base position.
    7,884
    Normal way of applying morphing is by using Node Editor.
    Vertex Maps > Morph Map.. to Displacement input.
    Once vertex is modified by Node Editor (and Morph Map node).
    It has to be subdivided by custom polygon handler.
