Results 1 to 2 of 2
Thread: Bugs
    Dec 2015
    Green Bay, WI
    18
    Bugs
    Is there anyway to downgrade software? I’ve had nothing but bugs with this last update. A 1080i SDI input on input 6 would not work, I reinstalled the software and that fixed that problem. I have been having a ton of issues with file copy not posting full files and also the control surface t-bar not staying at a correct percentage. It will just jump around around and never stay consistent to a number even if the operator is not touching the T-bar.
    Contact support and they can help you. It might be good to start to see if there is some other reason for the issues, as typically newer builds are usually more stable than previous versions.
    http://new.tk/support
