Results 1 to 15 of 16
Thread: lwo3 importer -> open source
    this one:
    https://www.lightwave3d.com/assets/p...y/lwo3-loader/
    make it open source, so other can integrate the new lwo3 file into their projects.
    One of the reasons there was / is a wide support to lwo was that it had their loader
    aviable as source and documented.
    Aug 2016
    a place
    2,013
    hope this happens
    San Jose, CA
    6,727
    Yeah, this needs to occur ASAP, and ideally with a BSD or equivalently-permissive license.
    John W.
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,687
    Quote Originally Posted by tischbein3 View Post
    this one:
    Will the lwo3-loader work with much earlier versions of LW?
    Or maybe i should ask, what versions of LW will the loader work?
    May 2006
    Bristol, England
    1,687
    Does anyone know if it does or not?
    Theory: it works based on the new engine, therefore, no.
    there is no sanctuary....
    Mar 2004
    Rochester Hills, MI USA
    479
    Quote Originally Posted by daforum View Post
    It doesn't work with 9.61 32bit. Says the loader failed to load.
    Bill Carey
    I7 6700K 4.0 ghz
    Win10 Pro 64bit
    32gig Ram
    Nvidia GTX 980 4 gb 417.71
    LW 2019.1 x64
    Space Navigator
    May 2006
    Bristol, England
    1,687
    Quote Originally Posted by UnCommonGrafx View Post
    Thank you for the info UnCommonGrafx
    Quote Originally Posted by Bill Carey View Post
    again, thank you for the info Bill
    Aug 2016
    a place
    2,013
    x64 only?
    San Jose, CA
    6,727
    x64 only?
    I suspect so.
    John W.
    San Jose, CA
    6,727
    Really shouldn't matter, it's back-porting LWO3 into older versions in the first place, so it isn't like ANY older versions have the new engine.
    As gar26lw noted, I suspect the main issue for back-compat. is due to it being a 64-bit plugin (and LWO3 is a 64-bit-native format, IIRC).
    John W.
    The SDK documentation has a full format description of LWO3, assuming it is accurate, just like it has had for the previous formats. I always assumed that documentation was the reason why LWO had wide support, that it was a well documented format. Over the years, or rather decades *shudder*, I've whipped up a couple of LWO readers, and at least for me it was always based on the format documentation.
    Going by the doc there is not a single 64-bit data type in LWO3 (not even double floating point vals) so there shouldn't be any 64-bit requirement dictated by the file format.
    Aug 2016
    a place
    2,013
    Quote Originally Posted by Myagi View Post
    what apps were the readers for?
    Oh, not for other regular 3D apps in my case, but readers/importers in my own projects (3D engines and tools).
    San Jose, CA
    6,727
    That doesn't sound right, are you sure you're not looking at the prior version?
    John W.
