Page 1 of 5 123 ... LastLast
Results 1 to 15 of 61
Thread: So Whos idea was it to remove Ambient Light?
    Because it was quite useful:/
    Jan 2016
    Stockholm
    1,481
    You can simply put a bit of illumination on the material you use to achieve the same result. I think they had to because they changed how the rendering engine is supposed to behave. I think it is OK really.. there are many things we need to do differently (and sometimes require more work) now.
    well.. illumination doesnt help if you need colored ambient light .. also if you have hundreds of surfaces
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,925
    It's for the best. Good decision. At some point I hope they remove all the lights on a "clear scene". Maybe in 2019.
    I dont mind it being turned off on default scene, but to remove it absolutely..
    Jan 2016
    Stockholm
    1,481
    Hmm, I think they need a light or the rendering engine would explode That said, I kind of agree on that. It is a bit annoying that I can't have an entirely clear scene, and add what I want from that. But it isn't a showstopper either.
    - - - Updated - - -
    Quote Originally Posted by dnch View Post
    Yeah I know.. but regardless. I'm actually happy they did what they did. Even if it means more work in that regard
    Feb 2006
    england
    1,431
    Environment light with no shadows?
    Mar 2012
    Socal
    505
    Turn on a little fog?
    - - - Updated - - -
    Turn on a little fog? Adjust the blackness level?
    Aug 2016
    a place
    2,484
    i used ambient a lot for npr stuff. not good.
    I usually turned ambient lighting down to two or zero for most of my rendering for my clients. Doing this I was able to more accurately get colors for my clients machinery for which I had to use stl models of for simulations. I relied on the lighting itself to get proper levels.
    Registered User caustics's Avatar
    Oct 2014
    Brazil
    114
    Image Processing -> Image Filter?
    Perhaps someone could provide a script to simulate the effect of "Ambient Light".
    Just an idea ... personally I didn't use it, so no loss for me.
    Super Member Chris S. (Fez)'s Avatar
    Virginia
    3,040
    Follow Corona render's lead where all tone-mapping and image processing filters are visible in the VPR. This will massively make up for no ambient lighting, which is essentially just brightening the rendered image.
    It is surprising it is not in 2018 already.
    Lightwave Pimp Skonk's Avatar
    Yorkshire UK
    1,454
    I only really used ambient for baking clean unlit UV maps with the surface baking camera. Setting the light to 0% and ambient to 100% so remove all shading.
    Can do it now by other means but all requiring more work than the ambient trick.
    uh wha?
    Aug 2006
    Eureka, CA
    7,114
    I used it.
    shrox www.shrox.com
    Heavy Metal Landing
    Aug 2016
    a place
    2,484
    the message that is coming across here is that removing things that are not mathematically correct or considered unneeded causes a lot of unforeseen problems for users. artists use the tools in unorthodox ways and this was one of lightwaves strengths. i think ambient should be added back in some form.
    what i am seeing, reading the forums is that there are simple and fast solutions in lightwaves workflow that are being replaced with more complex workarounds. that’s making lightwave slower and less lighwavey. too much of that over time will reduce its edge.
    we need the more advanced features and nodes but please consider the fast workflow too.
    the nodes button next to the simple solution was a great example in previous incarnations of offering both.
