Results 1 to 13 of 13
Thread: LW 2018 installer damaged on Mac.
    Super Member DBMiller's Avatar
    May 2003
    Vermont
    1,142
    I've seen a few people with trouble installing LW2018 on a Mac. I had the same issue with the installer being damaged after expanding. I used StuffitExpander instead of the Archive Utility that comes withe MacOS and it works fine.
    Mac OS 10.10.5 Yosemite, 2.66 GHz Core 2 duo, 4 GB RAM,ATI Radeon HD 2600 Pro
    I should update my Avatar Verlon's Avatar
    Earth
    2,354
    but it should still work on a clean install of MacOS.
    Also, someone said it worked with Stuffit 15, but not the latest version?
    Verlon Smith
    http://www.youtube.com/watch?v=g4i3XnbEKBw&feature=plcp - shameless prommotion for my daughter's horror (by 4 year old standards) story.
    May 2003
    Vermont
    1,142
    I have version 15 as well. Lucky I guess.
    yes got it to work using stuffit expander, off to a good start on the mac version then!
    Mar 2010
    SATown
    665
    After you unzip it, the Mac installer still has the Apple quarantine extended attribute left on. I'm not sure how or why that is.
    But, one way around it is to open the Terminal and type this...
    xattr -d com.apple.quarantine <file path>
    So on mine, it's like this...
    xattr -d com.apple.quarantine /Users/chilton/Downloads/LightWave_2018.0_OSX_installer.app
    And then you can double-click it to launch the installer.
    -Chilton
    May 2007
    Belfort, France
    1,854
    I didnít have to remove hte quarnatine with a command line. I just put up the unzipped file from the trashcan to the desktop and uncompressed with 7zip. Done. (Demo version on a iMac with a completely messed OS X install pf snow mountain, because I am on holidays with my older computer, so didnít try on Hish Sierra yet).
    Edit: i tried the first time with the unarchiver, which didnít work.
    Mar 2014
    Pennsylvania
    4
    Hello,
    The above fix for MAC installations worked fine. Thanks Mr ConjureBunny !
    I hope they are going to fix this. Wonder if no there tested it?
    Rob Depew
    Modeler/Animator/Editor
    Web Portfolio
    My Patreon
    YouTube
    Lightwave3D 2019, RF10, Gaea and more..
    Threadripper 32 core , 48gb, GTX-1070
    Asus 752vt i7 2.6 x 4, 48gb, GTX-970
    Nov 2003
    Austria
    827
    for me it worked with "7zX" , with the native mac uncompressing it does not work
    My Portfolio - http://alexs3d.blogspot.com - Now with Photography
    I am having problems with damaged installer; ConjureBuny mention opening the "Terminal". Where?
    thanks,
    Felipe
    Earth
    2,354
    Quote Originally Posted by Felipe Soto View Post
    thanks,
    Felipe
    Hit command and space, type terminal.
    Verlon Smith
    Thanks for the help Verion! Installing now!
    Earth
    2,354
    Alright, a quick step by step for anyone having trouble on the Mac.
    Once you download you LW2018, open a finder window and click on downloads so you can see the Lightwave_2018.0_OSX_installer icon.
    Press <Command> <spacebar> to bring up the finder window
    Type Terminal and hit <enter>. this should bring up the finder window.
    In the finder window type xattr -d com.apple.quarantine (do NOT press enter yet)
    Click and drag the installer icon from wherever it is to the space just after the .quarantine above. This will automatically fill in the path for you.
    NOW hit enter.
    Now double-click on install and watch it run as normal.
    No external software needed. I am not saying its okay, because this is a silly thing to get through testing, but at least you have your software.
    Verlon Smith
