Results 1 to 15 of 15
Thread: Enable Noise Filtering - how to?
    Mar 2006
    Delta Quadrant
    221
    It says preform a render to preview, but then I render and everything goes away. Any ideas on how to use this? Getting some noisy renders in stock 2018. Also happy new year!
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,923
    Same question here too. The only way I've been able to clean up renders is to crank up the Maximum Samples. So yeah - how does all this stuff work?
    Traitor
    Perth, Australia
    461
    In the 'render properties' window there's a button to 'Enable Noise Filter' then and button for 'Noise Filtering Options'.
    If you open your mind too much, your brain will fall out - T.Minchin
    Mar 2006
    Delta Quadrant
    221
    Yeah, I see those there. I have it checked and don't notice a difference on my renders. Also I'll render an image and it still says I need to render to preview noise reduction.
    San Antonio, Texas, USA
    13,056
    Enable in Render Properties AND in the output Buffers
    UI / UX Designer @ NewTek
    Mar 2006
    Delta Quadrant
    221
    Thanks Matt - from a UX standpoint I thought I was activating it from that first checkbox. I would have never thought to check output buffers. Just user feedback from a hobbyist though. Played with it all night, feels pretty solid. Congrats on the release!
    Aug 2004
    Ohio, USA
    4,923
    Thanks figured it out. Now just need to figure out the setting so I don't lose all my detail.
    Vacant, pretty vacant pinkmouse's Avatar
    South Yorkshire
    1,703
    Quote Originally Posted by Matt View Post
    As a UX designer, without your LW hat on, tell me, does that really make sense?
    Al
    "I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while." Charles Fort
    My Website
    My Lightwave Tutorials
    If you look at the dox, the way it's structured, yeah, it begrudgingly does make a boatload of sense.
    As it is Noise reduction PER buffer, turn on what you need and leave off what you don't. More a learning curve than a UI problem, I see.
    Robert
    South Yorkshire
    1,703
    So why not have the Output Buffers window open when you turn it on? That way it's completely obvious...
    Al
    My Website
    To keep a global toggle, in order to make testing faster...?
    I hear your concern, and somewhat agree with you. Had I not looked at the docs, I would probably be as irked.
    But I did and the way it is setup is cumbersome but logical. Only thing I need is a save function for keeping all the buffers I want on; or, as I surmise you have pondered, how can you see all those checks to turn them all on at once. Or quicker than one at a time.
    Preset Shelves. About time to have them for Renders. And it makes sense given all these new check boxes.
    Robert
    South Yorkshire
    1,703
    I've been saying for years we need a much better preset system.
    Al
    My Website
    Haha, what you have expressed a concern for may lead you through your wishes being answered.
    Pessac
    5,120
    Have you seen the presets system that Oliver Hotz has created in his ODTools? Have a look at any presets video in his toolset: https://vimeo.com/album/4335852
    B
    LightWave 3D Trial Edition
    South Yorkshire
    1,703
    Ben, you know as well as I do that this stuff needs to be integral.
    Al
    My Website
