Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 63
Thread: Known issues with LW2018?
  1. #31
    1,350
    If you spot something that shouldn't be there, or something that should, please use the Bug Report tool at the bottom of each page.
    B
    I like having a PDF version as I can add my own notes, high-lighting, etc. Can't do that with an on-line manual can you? Would be a really nice feature, but can't imagine that even being remotely possible.
  2. #32
    Mar 2006
    Delta Quadrant
    217
    There's a few chrome plugins if you use chrome Mark - https://chrome.google.com/webstore/d...apefmjbh?hl=en
    I agree it would be awesome to be able to do it natively within confluence though.
  3. #33
    Oct 2013
    UK
    43
    Glass behind glass goes black?
    Just playing a bit with the new materials.
    I am having this issue when placing a glass object behind a glass object.
    Any ideas as to why this happens?.
  4. #34
    Oct 2014
    UK
    573
    Quote Originally Posted by luzlight View Post
    I would guess its because you don’t have enough rays for the transparency, trying increasing the specular rays or one of the others?
  5. #35
    Dec 2014
    origin
    3
    Turning on 'Surface Shaded' under Object Properties > Edges crashes LW on render.
    Some strange deformations after FBX import(rigged objects), can't reliably recreate this one.
    Layout crashed after placing some spheres with VPR on.
  6. #36
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,473
    When importing old content for FiberFX, fiber thickness percentages become fiber thickness in meters, when it should be 100% = 0.05mm. So, the default 500% should be .25mm, instead of 5m.
    Also, you cannot submit a documentation bug report without an attachment.
    My Scripts for Lightwave
  7. #37
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,923
    I'm a little concerned about the AA. I can't for the life of me get rid of it in bright contrast areas.
  8. #38
    Is it just me, or does the Surface Editor windows, at least in Modeler, not remember the position of the vertical splitter nor the column width in the material list? I can resize the Editor window and it remembers the size next time Modeler starts, but it resets the splitter and columne width each time.
  9. #39
    Pessac
    5,046
    BV, is that the preferred way, or can we still submit thru the account bug report form?
    There are all sorts of ways you can, just get them to me (The bug reporter in the wiki, the same one in LightWave, user account, email, pigeon laden with note...)
    LightWave 3D Trial Edition
  10. #40
    Virginia
    2,938
    Ouch. Is that VPR or a final render?
  11. #41
    Pessac
    5,046
    Because you don't have enough recursion? Have a look in Render Properties > Render at the settings there.
    B
    Quote Originally Posted by WaveRider View Post
    Make sure you report each one with the nifty Feedback Reporter built into LightWave now...
    B
    If nothing else you can always attach a screenshot of what you are looking at in the wiki.
    B
  12. #42
    Aug 2004
    Ohio, USA
    4,923
    Quote Originally Posted by Chris S. (Fez) View Post
    Final
  13. #43
    Feb 2009
    Prescott, IA
    1,473
    B
    Which is what I did...
    Except I had to use good ol' shift-print screen to do it, then crop the image in GIMP. The feedback agent screen shot only works on the LW2018 window.
  14. #44
    Engineer/Entrepreneur Sekhar's Avatar
    Sep 2005
    Pasadena, CA
    2,124
    Could you give details, like surface, light, etc. so we can reproduce? I don't see any aliasing in VPR with default settings.
  15. #45
    Pessac
    5,046
    In that case, may I point you to an absolute lifesaver, used many, many times in the production of the wiki, ShareX. Have a look for it.
    B
