Page 24 of 25 FirstFirst ... 1422232425 LastLast
Results 346 to 360 of 363
Thread: OD 2018 Tool Set Released - And Now OD 2019!
  1. #346
    Wary Lamb Rejoining Flock Scott Gammans's Avatar
    May 2003
    Suburban Washington, DC
    258
    Hi Oliver! I think you already answered my question here, but to close the circle:
    Basically, I'm looking for an object-oriented overlay for LightWave's antiquated node system. It drives me crazy that I cannot define a node "class" that encapsulates a set of attributes and behaviors that I can reuse throughout my model. If I change the base node, the change should be automatically propagated to all materials linked to that node (or nodes that enclose that node).
    Basically, I'm looking for what the "Compound" node should have been from day one. LightWave's implementation violates the DRY principle, and makes it agonizing when a change in a core node must be carefully copy-pasted across dozens of descendant nodes manually. It's infuriating.
  2. #347
    Aug 2016
    a place
    1,828
    didnt xsi work that way? the correct way, the logical way?
    maybe truart’s global materials would help?
  3. #348
    May 2003
    258
    From what I understand XSI did indeed work that way (there is an entire thread on that subject elsewhere in the forum).
    Anyhow, it was super-nice of Oliver to point me towards one of his competitors; I don't want to hijack his OD Tools thread talking about DBW and TrueArt. Thanks again Oliver!
  4. #349
    Quote Originally Posted by Scott Gammans View Post
    ahh. ok.. i get it now... internally, i actually wrote a whole library i wrote that encapsulates all native/octane/3rd party nodes that i know about. so with that, i can easily say "create an image node with these parameters, create a material node, connect them in x fashion, and so on.... however, its not really something i plan on releasing. it was SO much work and I will call anyone attempting to recreate that completely crazy... but.. i really needed it for some specific stuff, and in the end, i guess I am glad i did it... it was extremely painful...
    Oliver
    OD Tools Purchase Link: http://origamidigital.com/cart
    Vimeo Channel: https://vimeo.com/channels/850417
    Join ODRoot - https://www.odroot.com
  5. #350
    Regarding DBW, we arent competitors.. we support and complement each other. Michael and I worked hard to make sure our plugins work with each other. Nodemeister works perfectly with my OD Uberpass for example... it didnt at the start, but we quickly worked on making sure it did..
    Oliver
  6. #351
    Stuttgart, Germany
    13,611
    Quote Originally Posted by oliverhotz View Post
    I was just about to chime in. Well, looks like I did. Yeah, we don't see each other at competitors and we certainly help each other out. The LW developer community is so small, we have to.
    Seriously though, we cover different areas and also have different philosophies when it comes to developing tools but we both want to advance LW. And we also recommend each other to our customers if we see a need.
    Having said that, thanks for the plug Oliver.
    Cheers,
    Mike
  7. #352
    Made a quick video showing how revolutionizing Uberpass really is for lightwave. A simple case study: https://vimeo.com/353067090
    Oliver
  8. #353
    Super Member COBRASoft's Avatar
    Dec 2005
    Oudenburg, BEL
    3,179
    Nicely done Oliver!
  9. #354
    Aug 2016
    a place
    1,828
    Hi Oliver, in latest OD tools, update scene has no update button as shown in the vimeo video. LW 2019.1.2
    Opening the scene reference master plugin will check and see that the scenes have changed, giving a pop-up warning but there is no way to reload them and the pop-up keeps appearing when you try and do anything and you cannot close the Scene references Panel.
    Clicking on the Reload Ref. Scene button doesn't seem to work. In this case, I have changed a model to an instance and expect to see an update. Is that button missing by mistake? Or is this a bug?
    A question regarding scene refs :
    can a scene have a motion mixer motions and the motion be adjusted in the motion mixer in the master scene?
    I am looking to reference the same scene with an animated hierarchy about 200 times and want to offset the motion of the reference animation.
    if not, perhaps you (or someone else) knows a way to do this in lightwave ?
    OT tools 2019 Requests :
    1.
    ability to clone a heirarchy with position and target constraints and have the resulting hierarchy work properly.
    If you try and clone a hierarchy with LW version or any other version I can find, it will break, as the clones reference the original targets as defined in the motion options.
    Additionally, it would be nice to be able to specify number of clones and an offset to the resulting cloned hierarchy.
    This is a real weak point in lightwave since as far back as I can see, judging by my searches in the forums. Thanks.
    2. Reference scene to import models as instances. If the same scene is imported multiple times (would be nice to have this option as a one button press) then all scenes with instances will reference the same objects so no duplicate masters.
    I'll look to enter this into your bug report tool but I need to find my l/p
  10. #355
    1.
    you're better of taking that discussion to discord.. too many things to reply here on the forum.
    Oliver
  11. #356
    I just sent out another version. This version also includes the Blender 2.8 version of the flipfluids to lightwave plugin among with other bug fixes and enhancements.
    Best,
    Oliver
    Oliver
  12. #357
    Murcia, Spain
    3,012
    Thanks Oliver, just got it.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
  13. #358
    Also the ODHoudiniShelfTools received a massive update today as well, also allows you to import lw motions now..... and.. most importantly...complete with the new asset library tool.
    Oliver
  14. #359
    San Jose, CA
    6,495
    Hmm, no signs of it here, either in main mailbox or quarantine.
    John W.
  15. #360
    its still going through sending out the mails... give it another 30 mins or so...
    Oliver
