Page 22 of 23 FirstFirst ... 1220212223 LastLast
Results 316 to 330 of 343
Thread: OD 2018 Tool Set Released - And Now OD 2019!
  1. #316
    Super Member omichon's Avatar
    Bordeaux, FR
    716
    Thanks for the update, Oliver !
  2. #317
    Murcia, Spain
    2,972
    Thanks Oliver
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
  3. #318
    I'm finally getting around to buying some of these tools! I was hoping for a better US>CDN exchange rate but looks like it won't be happening for a long while. Oh well.
    Just curious as to why OD PieMenu is a Layout only plugin? Is there a chance it will be carried over to Modeler?
    Humans are pretty much monkeys with car keys.
  4. #319
    Quote Originally Posted by Signal to Noise View Post
    unfortunately not possible in Modeler... I've logged requests with newtek to make some changes so that it could be possible, but, nothing has changed there.
  5. #320
    Hi Guys,
    Over the weekend, we've had our 1000th sale since opening the new and improved store in April 2019. That's simply incredible and I want to thank each and every one of our customers. Whether you have purchased ODTools for Lightwave or the Shelf Tools for Houdini or the incredible and one of a kind OD Uberpass, or frankly, any of the other products, you have all contributed to an incredible run. There are also quite a few free tools in the store that if you haven't checked them out, don't forget about them.
    Having achieved this milestone, prompts me to do something I haven't really done before, and probably, won't do again, so for the next two weeks
    you can get any of the products (or updates) at a 15% discount (COUPON Code: 1000) until July 8th, 2019.
    YOU SHOULD BE ABLE TO ADD THE DISCOUNT CODE WHEN VIEWING YOUR CART.
    The coupon applies to the following tools:
    Lightwave: ODTools 2019 & Upgrade, OD Uberpass, OD Pie Menu, OD Substance Reader, OD Workspaces
    Houdini: OD Houdini Shelf tools (also very useful for Lightwave Artists)
    Store: https://origamidigital.com/cart
  6. #321
    That's amazing news Oliver, congrats on that milestone and thanks for all that work on so many indispensable LW plugins which are part of my everyday pipeline for quite some time.
    RAM-Studio
  7. #322
    6,472
    All origamidigital.com links in your post are currently giving "502 - Bad Gateway (nginx 1.14.1)" errors here.
    Anyone else encountering similar?
  8. #323
    i see it too... was fine 15 mins ago.. contact tech support.. hopefully will be fixed soon... maybe the new traffic crashed it.. lol... will update when its back.. Sorry john.
  9. #324
    Its amazing how that works.. you do a new thing... publish it.. site goes down at host.... these kinda things, i find as reliable as you can bet on smoke detector batteries failing ONLY in the middle of the night.. never during daytime..
  10. #325
    looks like its back up.
  11. #326
    1,764
    yep, website working, Upgraded, thanks.
    In the course of fiddling around with bone chains, spline deform and instances, I have a couple of requests that might be useful to others:
    Layout - a way to assign a weight map to a bone based on a name or part of a name of a bone.
    Layout - Select n'th for items, like the modeller version
    Layout - A curve to spline tool that allows for a spline to be created with a user specified number of points - good for a spline that is to be used with spline guide, it gives a far more predictable (read usable) result. Without this, things do not work properly with curving/rotating objects following a path.
    Modeller - an x64 version of the old Dstorm tool that will divide a curve into a set amount of segments, via knots or evenly spaced divisions
    link to old x32 only version http://www.dstorm.co.jp/dsproducts/F...thDivider.html
    Modeller - a curve to motion exporter that works properly with curves generated in modeller - LW one seems unreliable.
    Right now, to achieve some of this stuff workarounds must be used involving 2015 and 2019 and things are very time consuming (read frustrating )
    cheers
  12. #327
    cheers
    regarding the modeler tools... Subdivide Curve has existed for a while as part of the ODToolset, and a curve to motion was added in OD2019 (poly to motion). Regarding any spline related stuff for layout, best to ask Michael Wolf and check out his Patreon as he's currently working on Layout spline related things. Regarding the nth select for items... can you provide a use case, on when you would use that ? The weight assignment based on part of bone, I believe already exists.
    Best,
    Oliver
  13. #328
    Time goes fast.. last 4 days of the 15% Discount on any OD Product..
    The coupon applies to the following tools (all commercial products):
  14. #329
    Top Dog
    Aug 2005
    Los Angeles
    1,057
    Hi Oliver, did expire as of today (July 8) or on today? I tried the coupon code right now but it says expired.
  15. #330
    I guess i had set it on today... I just extended it until the end of the day today (july 8th 2019) (which it was supposed to be)..
