Results 1 to 15 of 23
Thread: Fixed Autokey mode, Multi-Selection Editing of Modifiers. etc..
    Sep 2015
    Sweden
    586
    Now that we have a release date, can we PLEEEEASE start geeking out about features again.
    Most of the stuff we have seen before but I wonder what the extra features at the bottom of the 2018 feature list are.
    Multi-Selection Editing of Modifiers seems like it could be a real timesaver, because right now it is a real thorn in my side that we don't have that.
    does that include node networks? Tell me! Tell me!
    Fixed Autokey? whats that?
    Questions! Questions!
    San Antonio, Texas, USA
    13,055
    Not in terms of editing the contents inside node networks, but the adding / removing / copy / pasting of modifiers.
    Allows you to specify a keyframe to _always_ key on no matter where you are on the timeline.
    UI / UX Designer @ NewTek
    Super Member Chris S. (Fez)'s Avatar
    Virginia
    2,955
    Matt, there is no mention of improved mesh performance in the marketing material. Did the new mesh engine mentioned on the blog not work out?
    13,055
    Quote Originally Posted by Chris S. (Fez) View Post
    Layout does have speed increases when dealing with meshes yes.
    Virginia
    2,955
    Quote Originally Posted by Matt View Post
    Great. Thanks.
    Sep 2015
    Sweden
    586
    So does this mean I can edit a node network and then copy paste it to multiple objects at once without having to cycle through them?
    Always key seems like a great addition sort of the opposite of the way Maya blender etc. do it but I don’t see why it won’t work.
    Fixed Autokey Mode: YAY YAY, no more creating keys at the wrong frame. Nice little addition! I know the Maya folks will like that!
    Sep 2015
    Sweden
    586
    Thanks for the info! It’s like Christmas. Could you elaborate on the layer improvements in modeler?
    13,055
    Scripts to manage working with layers better:
    • Search Layers - Allows setting of FG / BG layers from a searchable list
    • Find On Layer - Finds which layers polys reside on by setting the FG layer of any selected polys
    • Next Layer - Advances all selected FG layers by 1 but keeps any BG layers you had selected (until a selected FG layer replaces a BG layer)
    • Page Down hotkey re-assigned from 'Next Lyr Bank' to 'Next Layer'
    • Prev Layer - Decreases all selected FG layers by 1 but keeps any BG layers you had selected (until a selected FG layer replaces a BG layer)
    • Page Up hotkey re-assigned from 'Prev Lyr Bank' to 'Prev Layer'
    • Select All FG Layers - Selects all FG layers but keeps any BG layers you had selected
    • Select All BG Layers - Selects all BG layers but keeps any FG layers you had selected
    • Select FG Lyr Range - Fills foreground layers between two foreground layer selections
    • Select BG Lyr Range - Fills background layers between two background layer selections
    • Insert / Delete Layers - Respect pivot points
    Also added:
    • Reassign Surface - Allows reassigning of surfaces based on a name search match
    • Select Surfaces - Allows selection / deselection of surface names using a list of surfaces versus the single selection in the Stats panel
    • Rotate To Axis - Allows rotation of geometry to XYZ axis using the normal of the first poly selected as a reference for rotation
    Super Member jboudreau's Avatar
    May 2003
    Halifax
    935
    Also added:
    Are these scripts that you made?
    VFX Artist / 3D Animator
    Animatrix Productions
    Dell T7600 Dual XEON E5-2687W 3.8GHz / Dell M6700 i7 -3940XM 3.9GHz
    64GB Ram / 32GB Ram
    Nvidia Quadro K5000 / Nvidia Quadro K5000M
    Windows 7 x64
    Axes grinder- Dongle #99
    Seattle
    14,732
    This one slipped by me: Auto Key: FIXED
    This is a way of getting the feature I prefer to call "STATIC ITEM". Glad to see it got implemented.
    Praise to Buddha! #resist
    San Jose, CA
    6,511
    IMO, it seems like "Auto Key: Fixed" is somewhat orthogonal to a couple of the other auto-keying options, specifically "existing", "modified" and "all". Put another way, whether I want auto-keying fixed to a given keyframe is an independent decision from the channels I'm allowing auto-key to alter.
    It really needs four controls: A checkbox for activating/deactivating auto-keying, a drop-down for selecting whether auto-keying affects existing|modified|all, a checkbox for whether to auto-key to a specific frame (aka "Fixed"), and a numeric field for which frame number receives fixed auto-keying. If fixed is always frame zero, the last field can be omitted. The way the controls work now, using fixed-frame auto-keying needlessly blocks users' ability to control which channels auto-keying is allowed to impact.
    Filed as LWF-1967.
    John W.
    LW2015.3UB/2019.1.4 on MacPro(12C/24T/10.13.6),32GB RAM, NV 980ti
    13,055
    It has both of these.
    San Jose, CA
    6,511
    I think you're missing my point. The issue is that, given the existing controls, you can't turn on fixed-frame and also control which channels auto-keying alters. I was proposing a set that would allow access to controlling both fixed frame, and also what channels auto-keying alters. See LWF-1967 as well.
    I wasn't saying it didn't have ANY of those controls I listed. However, having both of those doesn't solve the issue.
    Also, w.r.t. frame #, opening "General options" allows (well, is supposed to allow) access to the setting defaults, but in the case of frame #, it's not really accessing the default frame # value, it's accessing the current frame # value. Is that worth filing as a bug by itself, or is LWF-1967 adequate?
    I know there are a bunch of other "current-masquerading-as-default" fields in prefs. However, in that specific case, the Auto-keying control immediately above explicitly says "default". I'll argue it's ambiguous/confusing UX for Auto-key frame # to access "current".
    John W.
    Seattle
    14,732
    https://www.lightwave3d.com/account/report/LWB-4200/
    I've reported there's no dox currently for FIXED, and there's something that is worrisome: if a user engages FIXED mode, does it ERASE all existing keyframes?
    ::test test test:: No, it does not, but it IS wierd: Animate an item along a path without FIXED engaged, w/like 5 keyframes, including frame zero. Engage FIXED. Now put the timeline cursor at , oh, 60, and move the item.
    I'm not sure what's happening, but it's weird, and it doesn't seem like the frame zero keyframe is being updated. It's very puzzling.
    Frankly, it would be BETTER, or at least less confusing, if engaging FIXED destroyed all other keys. At the very least, the current behavior requires documentation to make clear what's happening.
    ADDENDUM: ....nah, still confusing. Really, guys, STATIC CHANNEL did it correctly.
